07-12-2015, 06:47 PM | #1 |
Painting ac cmpresser brackets
What kind of paint should I use to paint my ac compression brackets. They are bair mettle and I want to paint them black.
07-12-2015, 09:49 PM | #2 |
Re: Painting ac cmpresser brackets
Any standard automotive/metal spray paint you buy at the parts or hardware store should work. Get an etching primer and lay down a few layers of that, and then whatever black suits your fancy.
Posted via Mobile Device |
07-13-2015, 12:29 AM | #3 |
Senior Enthusiast
I have found that Rustoleum Gloss Black appliance epoxy spray paint is nearly as hard as power coating, and would work well in this application. Years ago I had all my Alan Grove engine brackets powder coated, and they have held up extremely well. But if I had to do it again I'd simply spray them with Appliance Epoxy which is cheaper and quicker.
If you use this, get a good respirator to protect your lungs and paint outdoors if possible.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
07-13-2015, 10:27 AM | #4 |
I like the VHT satin black. It's closer to the original sheen then gloss black is.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
07-13-2015, 12:56 PM | #5 |
Chevy addict
Rustoleum 2 in-one semi gloss black works great in spray cans.
07-13-2015, 09:09 PM | #6 |
My biggest concern is heat. Will all of those stand up to the engine heat?
07-13-2015, 09:27 PM | #7 |
They will stand up to heat, but the bolts that hold it all together will probably grind/scrape off the rustoleum as you tighten and flake/rust out eventually. Not trying to bum you out, just my experience.
