carb and ignition question
I have a 64 c10 with a 292 and rochester b carb and hei that i can't identify as to manufacturer. had the carb rebuilt and valves adjusted by a reputable shop close by. ran great for a few days and even better with fresh plugs until today.when i accelerate there is a hesitation before it reacts. i have the plugs gapped at .037 because i have read you can increase gap slightly for hei.
my next question is about running dedicated 12 volt wire to hei. where does the wire run from? i can take truck back to shop as it is under warranty but wondered if i should regap plugs back to .035? ![]() |
#2 | |
Post Whore
![]() Join Date: Mar 2013
Re: carb and ignition question
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
good advice TJ. definite change when i sprayed around base of carb. easy fix.
also tried increasing spark plug gap but it would barely run at all. i don't have a voltmeter but wonder if i can run wire straight from positive side of battery to dizzy to insure I am getting 12 volts. ![]() |
![]() Join Date: Jul 2007
You can run a new wire from the ignition . The old one probably is a resister wire. Did you see if your Vac advance is working? I had a carb done and the accelerator pump was defective and it had to come apart again. The guy said he installed a heavy duty one. Why are they all not the heavy duty ones? Makes no sense.
Easiest route to get the power to the HEI
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
thanks for the picture 63. I'll get er done along with other wiring I need done and then let the guy who rebuilt carb check that out. He said old accelerator pump was shot out real bad.
No problem. I just did the same conversion as I went from points to HEI. Was a simple conversion, but the diagrams help a bunch.
#8 | |
Post Whore
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw Last edited by TJ's Chevy; 07-14-2015 at 10:38 AM. |
thanks T.J.
