Old 07-13-2015, 09:51 PM   #1
Mathew21
Mathew21's Avatar
Anyone using a Lokar Cable Column Shift Linkage
Fist off this is my first engine/trans swap I ever done. I'm learning as I go. I usually stay up all night reading different threads looking for the answer I need. But I had no luck finding the answer to this question.
I installed a Generation III 5.3/4l60e in my 66'. The exhaust manifolds interfered with the stock transmission linkage. So I bought Lokar Cable Column Shift Linkage. I started to install it the other day. In the instructions it shows you how to install the parts on the column but it does not say how to modify my column to do the install. I'm assuming I need to remove all stock parts on column to make it work. But this is what me nervous. I'm worried if I remove the detent that keep it in park that this is going to cause problems. I'm I over thinking it or will the linkage on the trans take care of it?
In case I used the wrongs words to describe what I'm talking about I will post a picture of the part on my column I'm referring to.
Here's the insructions:
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 07-13-2015, 10:14 PM   #2
LT1 Burb
LT1 Burb's Avatar
Re: Anyone using a Lokar Cable Column Shift Linkage
I put a lokar on my suburban but it was linkage, you might want to look at that option. It was a 700R4 column shift.
LT1 Burb is offline   Reply With Quote
Old 07-13-2015, 10:24 PM   #3
Mathew21
Mathew21's Avatar
Thanks for the reply. I had a 700r4 in my truck before this with the stock linkage. I really don't see anyway I could use a regular linkage with the exhaust manifolds (trail blazer SS) I have on the motor. They dump right where the linkage goes.
Old 07-13-2015, 11:32 PM   #4
LT1 Burb
LT1 Burb's Avatar
I was thinking the 5.3 was similar as to where the exhaust dumped but I guess not. I'm thinking, by looking at that column bracket that it should work fine and not interfere with your park at all. There should be enough play in the cable to accommodate the Park lock.
Old 07-14-2015, 10:04 AM   #5
MikeN
MikeN's Avatar
I've never been inside a 4L60E, but on TH350 and TH400 there are detents inside the transmission. I don't see how the transmission could slip out of gear even if the column didn't have detents. Maybe we can find a photo of the 4L60E innards.
MikeN is offline   Reply With Quote
Old 07-14-2015, 10:07 AM   #6
MikeN
MikeN's Avatar
This is from Shiftworks's website, and shows the "rooster comb" inside a 4L60E. Seems like it provides a positive lock into each gear, even in the absence of detents in the shifter itself.
http://www.shiftworks.com/pics/rooster-comb-lg.jpg
Old 07-14-2015, 10:10 AM   #7
Mathew21
Mathew21's Avatar
Awesome Thanks!
Old 07-14-2015, 02:16 PM   #8
TopFuel1966
TopFuel1966's Avatar
I have the Lokar cable shifter on my 4L60E with a Flaming River column. Works great. The detents are in the transmission, not the column.
TopFuel1966 is offline   Reply With Quote
Old 07-14-2015, 02:39 PM   #9
Mathew21
Mathew21's Avatar
Great information, Thanks
