Old 07-13-2015, 09:57 PM   #1
Northern lights
cpp power steering
It appears that I am going to have to go with power steering on my '57. Keeping the straight axle. Talked to "Vance" at cpp and was told that the entire conversion setup is about $950. Anybody have experience good or bad they would lime to share regarding this setup?. Are there better conversions available?
Northern lights is offline   Reply With Quote
Old 07-13-2015, 10:02 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: cpp power steering
Which setup? they have two
dwcsr is offline   Reply With Quote
Old 07-13-2015, 10:33 PM   #3
Northern lights
I didn't know that and it was not mentioned. What is the difference in the two and which one is preferred?.
Old 07-13-2015, 11:53 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
They sell a 5559PSKA which is a "power assist" kit using a hydraulic cylinder and a control valve. Its made to order and take a long time to get. This was the type used in 57 and they have a kit 4759PSK-S500 that mounts a late model steering box on the frame. With either one you need a PS pump/brackets/pulleys/ belts for what ever engine you have.
Old 07-14-2015, 12:20 AM   #5
Northern lights
The one I was told about would be the 4759psk-s500 then and the $950 was for everything including the pump, brackets, pulleys belts etc. Is it a well domne conversion?. Quality parts? Worth the $'s?
Old 07-14-2015, 12:54 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
I don't use their parts so I can really say. Some here don't like that kit because when turned all the way it rubs on the tire or the tire rubs on the box.
Old 07-14-2015, 02:36 AM   #7
AK56
AK56's Avatar
They do sell a kit that bolts up the original box position which shouldn't limit tire clearance.
I don't know anything about it. You might research it for reviews.
Not much info on their site.
Here's a link
http://www.classicperform.com/Series...eringBoxes.htm
Good luck!
AK56 is offline   Reply With Quote
Old 07-14-2015, 12:08 PM   #8
Old Crow
Old Crow's Avatar
I just used one of the kits listed on AK56's link on my '61 F-100 shop truck. I won't bore you because it's an OT truck, but the installation wasn't that hard, and the feel of the truck is actually much better than the '58 we did with a late model Chevy box.
Old Crow
'54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ
Old Crow is offline   Reply With Quote
Old 07-14-2015, 03:08 PM   #9
OrrieG
OrrieG's Avatar
I looked and that kit is currently $795 plus shipping. I then priced the parts available locally and found I could get the steering box, steering pump, hoses and bracket for $240.00. I have the metal to fab the two frame brackets in the shop. for the $550 difference I would drive to NAPA and buy the parts. On my truck I had all the parts from various donor rigs, only expense was a piece of 3/8" plate I did not have. A little measuring and cardboard templates and you are good to go. I have fabricated all the brackets on my truck because I just could not bring myself to pay thousands of dollars for stuff I actually enjoy making.
OrrieG is offline   Reply With Quote
Old 07-14-2015, 07:41 PM   #10
qbeanie
Summit racing has that kit at a lower price. Sounds strange that summit is cheaper but it is. Type in the part number on summit site and it comes up. Good luck.
qbeanie is offline   Reply With Quote
