Old 07-14-2015, 12:42 AM   #1
rosefabworks
61 c20 motor mount perch???
I am doing a 61 c20 with a 454 with a 4l80e so I need the side mount perches and im having trouble deciding what perches I need. ive built my own front crosmember so I don't have the lower bolt hole for the perches and my frame has no holes on top for the perches near the opening. so im wondering what perches would be best and how to locate them without any holes.. any advise would be much appreciated
rosefabworks is offline   Reply With Quote
Old 07-14-2015, 08:28 AM   #2
1963c-10
1963c-10's Avatar
Re: 61 c20 motor mount perch???
Best mounts I've found for the big block conversions if using headers is the POL mounts. I ran 2" primaries off of them on my big block build. My guess is you'd have to weld them in if you don't want them bolted in.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-15-2015, 12:33 AM   #3
Captainfab
60-66 Nut
There aren't going to be any aftermarket engine mount brackets that will fit the '60-'62 frame without either a spacer on top of the frame or the need to be modified. The factory brackets for a '67-'72 with a small block will fit an original crossmember truck fairly closely, but those may not work in your application. Those engine mounts aren't known for their toughness anyway. When I installed the big block in my '66 Suburban, I used the '73+ engine mounts and clamshells, as in my opinion, those are the best factory engine mounts. Then I fabricated my own brackets to mount them to the crossmember at the height and angle that I wanted.
As far as locating the engine and trans in the frame, you will have to set the engine and trans in the frame and move it forward and backward to get the clearance you want between the firewall and heads/valve covers. The further back the better.
Old 07-15-2015, 12:42 AM   #4
rosefabworks
thanks captainfab in the other threads on the subject most are saying to shim the perch up by an inch is that correct? il be using the performance online mounts for 63-66
Old 07-15-2015, 12:57 AM   #5
Captainfab
60-66 Nut
I do not know that answer as I have not used those brackets. Only factory brackets or the ones I have fabricated. Since you do not have the factory suspension crossmember, what works for others may not work for you.
Old 07-15-2015, 08:55 AM   #6
1963c-10
1963c-10's Avatar
Check Erics build thread. He's using the POL mounts on his 62. Some pics to show the space between the mounts and the frame. Looks around 3/4"- 1"
His build: http://www.67-72chevytrucks.com/vboa...=608776&page=2
Old 07-15-2015, 11:25 AM   #7
63burban
Chevy addict
Interesting ! you built your own front crossmember but not the motor mounts ?
63burban is offline   Reply With Quote
Old 07-15-2015, 12:28 PM   #8
61K10
61K10's Avatar
post up a pic of your x-member. I sure some would like to see it.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 07-17-2015, 03:23 AM   #9
rosefabworks
I guess I am just gonna fab up some motor mounts. I was a little uneasy about it at first because I wasn't sure of exactly where to put it but from what I gather it just needs to be square with the frame and as far back as possible.
Old 07-17-2015, 12:24 PM   #10
61K10
61K10's Avatar
Now that's a x-member--looks cool.
1961 chevy K10
Old 07-18-2015, 01:23 AM   #11
Captainfab
60-66 Nut
When fabbing your engine mount brackets, keep in mind that in the end your trans output shaft needs to be the same angle as your pinion.
