07-14-2015, 01:38 PM | #1 |
steps support weight of cab w/doors + glass?
I need to pull my cab off the frame. Instead of lifting the cab, I plan to build two dollies under the length of the cab steps then drop the frame out from underneath.
My question is can the steps support the weight of the cab with the doors and glass installed? There would be two 2 x 4's running the length of the steps on either side of the brace underneath the step. I don't otherwise have a need to remove the doors and I would like to avoid it if I can. I just finished welding in new floor pans/braces/hinge pockets so the cab should be structurally sound. Any advice/pics of anyone who has done it this way would be appreciated. Thanks in advance.
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
07-14-2015, 02:48 PM | #2 |
Re: steps support weight of cab w/doors + glass?
Here is how I supported mine, but I had the doors off. It was supported on the brace that runs the length of the step. I think it will also support the additional weight of the doors.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-14-2015, 03:26 PM | #3 |
Thanks for the pics Orrie, that's right along the lines of what I was planning on doing. The seat, and steering column are out of my cab but I wasn't sure about the extra weight of the doors and the glass. My gut feeling is it should be fine, just looking for some reassurance.
