Old 07-14-2015, 05:56 PM   #1
J1MMY
Trivia time - what is this on the column?
what is the metal bracket/lever just beneath the ignition barrel? I do not have one on my column change version..
'63 C10 Longbox fleetside
'94 C1500 Sierra ex-USAF beater
J1MMY is offline   Reply With Quote
Old 07-14-2015, 06:05 PM   #2
69heavychevy
69heavychevy's Avatar
Re: Trivia time - what is this on the column?
gear indicator??
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 07-14-2015, 06:11 PM   #3
bhc41051
bhc41051's Avatar
I don't know what it is but I used to live in Compton Bassett, near Calne right off the A4.
bhc41051 is offline   Reply With Quote
Old 07-14-2015, 06:12 PM   #4
J1MMY
It's out of a floor shift manual vehicle.
I was thinking some sort of key release button but really don't know.
Old 07-14-2015, 06:13 PM   #5
J1MMY
Oh yeah? I'm a Bristolian but moved out just north of Swindon 18 months ago. Loving the quieter life. How long have you been across the pond?
Old 07-14-2015, 06:17 PM   #6
Jeff's bowtie's
You have to push it down to move the switch to the lock position and remove the key
Jeff's bowtie's is offline   Reply With Quote
Old 07-14-2015, 06:30 PM   #7
natedogg
x2. I had a 92 S10 that had that, but I have never seen it on a square?
natedogg is offline   Reply With Quote
Old 07-14-2015, 06:39 PM   #8
burban nate
my 85 4-speed c30 had it.
Nate
Current Project: 1990 V3500 CC dually.
burban nate is offline   Reply With Quote
Old 07-14-2015, 06:43 PM   #9
bhc41051
bhc41051's Avatar
I was stationed at RAF Greenham Common with the USAF from 1985-88. I'm glad to hear it's still quiet there, that's what I miss the most about the UK.
Old 07-14-2015, 11:46 PM   #10
raceman6135
Dino burner
raceman6135's Avatar
x4
My 1980 GMC K20 has it. Floor-mounted 4-speed manual transmission.
raceman6135 is offline   Reply With Quote
Old 07-15-2015, 12:21 AM   #11
mongocanfly
Post Whore
mongocanfly's Avatar
Same thing on my 81 with 4spd..
Old 07-15-2015, 12:22 AM   #12
mongocanfly
Post Whore
Same thing on my 81 with 4spd..may have only been on manual trans trucks..it won't let switch go into the off position unless you press it
Old 07-15-2015, 03:14 AM   #13
Titomars
Titomars's Avatar
The lever is used only on floor shifted trucks. Automatics the shifter is the interlock. It is called a ignition interlock.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 07-15-2015, 04:06 AM   #14
J1MMY
I was only young at that time but wasn't that when the anti-nuclear protests were happening? I remember seeing it on the news around that time.
Thanks guys, this thread is full of positive enforcement
Old 07-15-2015, 07:41 AM   #15
Keith Seymore
Keith Seymore's Avatar
x7. On my '87 with a floor shifted manual trans.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-16-2015, 10:45 PM   #16
oldwagon
oldwagon's Avatar
When I acquired my 83 dually, with a manual transmission, the original column had been replaced with a column that had the shift lever removed. I'm guessing it was an automatic. I had that one replaced with the manual shift column. Hence the locking mechanism.
oldwagon is offline   Reply With Quote
