07-14-2015, 11:06 PM | #1 |
Born Psycho
72 blazer 4x4 frame and running gear
complete 72 blazer frame, good running 283, turbo 350 trans, 205 t-case, dana 44 with disc brakes, 12 bolt rear, tag on front diff says 3:08 gears. frame is straight but previous owner cut off the ends of the frame in the rear behind the last body mount hole so it looks like a 71 style frame. has all crossmembers and a clear california title with VIN plate. i will start the engine so you can hear it run prior to purchase, transmission worked before we removed the body. frame is solid-NO rot out anywhere. will try to post pics if anyone is serious about buying it. $1100.00 takes it away.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
07-15-2015, 10:15 PM | #2 |
Born Psycho
Re: 72 blazer 4x4 frame and running gear
took the pressure washer to it tonight to get rid of 40+ years of dirt and grime and this frame is real solid-still had some black paint under the dirt
07-16-2015, 12:51 AM | #3 |
Too bad the rear part of the frame is cut I would love to restore a frame while I drive my truck. What exactly is the reason for cutting it?
Kirk 72 Blazer CST 4wd highlander 66 Nova |
07-16-2015, 09:28 AM | #4 |
Born Psycho
i have no idea why it was cut. i bought it to get parts missing from the blazer i'm building for my 84 year old dad. the frame still functions fine, it just looks like a 71 instead of a 72.
07-26-2015, 12:07 AM | #5 |
Born Psycho
sold it locally
