07-15-2015, 06:14 PM | #1 |
What dual master cylinder needed.....?
Hi Folks,
I want to upgrade my single master cylinder to dual master - 66' C10 step side - drums all round . Having looked around I'm finding myself confused about which to get and from whom!, I'm not interested in having power brakes, and I will be sticking with drums for now. Trouble is I can't just pop down the auto parts store as we don't have them here (for our trucks) in the UK and the good lady indoors won't allow me to come to USA just to go parts shopping ........... Yet! As I said I've been looking online at summit - classic - brothers but I seems the more I look the more options I find and then the more confused I get about which is the right one for my application? Any and all help will be greatly appreciated over here, thanking you T' da D Posted via Mobile Device |
07-15-2015, 06:46 PM | #2 |
Re: What dual master cylinder needed.....?
if you can get a hold of a Master cylinder from a 67, you will have what you need. Just remember to split the brake lines front to rear.
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
07-16-2015, 12:19 AM | #3 |
60-66 Nut
All you need is a master cylinder for a '67-'70 C10.
07-16-2015, 03:25 AM | #4 |
Excellent- thank you guys.
That clears up the confusion, have found this at rock auto will this particular MC do the job https://www.rockauto.co.uk/catalog/m...nid=486&jpid=5 Ta D Posted via Mobile Device |
07-16-2015, 02:09 PM | #5 |
Looks right.
s |
07-16-2015, 05:41 PM | #6 |
I ordered the MC for a 67 from Rockauto. Even with freight it came at a saving from what I could get here.
On our trucks, front line out of the cylinder to front brakes, rear line to rear brakes? What happens if they are reversed? |
07-16-2015, 08:40 PM | #7 |
I think on my S10 MC its front brakes to rear and rear brakes to front of the MC...someone correct me if I'm wrong..but in your case might not matter...as its drum/drum and no proportioning is needed...
07-17-2015, 12:31 AM | #8 |
60-66 Nut
On the '67-'70 master cylinders, the front port is front brakes and rear port is for rear brakes. Not all master cylinders are designed the same.
07-17-2015, 07:50 AM | #9 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-17-2015, 07:52 AM | #10 |
Thank you but are you sure on that as I've read here so much that the larger line is for drums needing more fluid...
07-17-2015, 07:54 AM | #11 |
Here's a typical set up....
07-17-2015, 07:56 AM | #12 |
Confusing for sure...but this has rear on front
07-17-2015, 11:32 AM | #13 |
In the 67 reservoir the chambers are the same size and IIRC they did not use a proportioning valve.
Captain confirms that front line to front brakes and rear line to rear brakes, so I've got some swapping to do. Seems to work perfect as I have it though. |
07-17-2015, 02:28 PM | #14 | |
Pretty sure; I was a brake development engineer for GM Truck. K
07-17-2015, 02:50 PM | #15 |
07-17-2015, 04:11 PM | #16 |
I am finding a lot of folks have their brakes wrong if you look at this one the front discs are hooked to the rear smaller reservoir and have smaller lines. reading the posts after this one the front are the ones that split after the prop valve...
07-17-2015, 08:27 PM | #17 |
I'll tell you a funny story...I emptied the MC and found the rear chamber to be larger than the front...it's an optical illusion for me as it seems taller up front...it explains a ton!
09-15-2015, 12:28 PM | #18 |
A day late and $1 short...
Does anyone sell a kit with pre bent and flared brake lines for this upgrade?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
