Help with dome light.
I just pulled the wiring for the old dome light, I installed the new Dome light in, after plugging it in, it doesn't work, anyone have suggestions on why?
Re: Help with dome light.
Bulb any good?
Check the power and ground at the bulb socket. If yes, replace the bulb. If no, make sure good connection at the plug and double check power and ground at the plug. Also, try a lot of swearing. I usually have to find the right swear for the job. Once you find that, repeat it as much as possible and louder each time.
'62 C10 LWB fleet side. 283 w/ a T5 |
Ditto what HumphreyMurdoch said ... check the bulb, power, and ground.
The orange wire is power and should be live all the time. If not, check the fuse. The white wire is a switched ground. It is grounded through a set of contacts in the headlight switch when the knob is rotated fully counterclockwise. And for this to work, the body of the headlight switch needs to be making a good ground connection with the dash via it's retainer nut. |
#4 | |
#5 | |
Sometimes just because they are new and shiny does not mean they are good. Put 12 volts to the bulb or you can use a Power Probe to check from the plug. Make sure you are getting a good ground. The Power Probe provides both. Best tool in the box!!
#7 | |
Hooligan
The Green Hornet 1960 Apache 10 Long Fleet - Driver and Work In Progress The Death Star 2006 Vstar 1100 - Chopped, Bobbed, Riding the Dark Side |
I know some guys mentioned this earlier but are you turning the correct switch all the way counter clockwise?
When I first installed my dome light I thought mine didn't work, but I wasn't turning the switch far enough. I don't remember the exact issue, but I think I expected the light to gradually turn on as I rotated the switch, like modern car would. It took me a minute or two to realize. |
Did the dome lamp work prior to replacement?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
![]() Join Date: Jul 2009
Bypass the switch with a jumper wire to ground. If the light comes on repair or replace the switch.
Post Whore
![]() Join Date: Mar 2013
Sometimes kicking it works....on my 64 GMC I went to turn the head lights on and nothing happened....got out and kicked the grill. Problem solved.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#13 | |
#14 |
First, don't assume that because it's new it works.
1. Is the headlight switch in the right position for the dome light to come on (rotated all the way left if I recall correctly)? 2. Does the power wire have power? 3. Is the fuse blown? 4. If the power wire has power, is the bulb bad? 5. If the bulb is good, and the power wire has power at the bulb, is the grounding good? |
#15 |
So it was the light switch, I had no idea that it worked that way, it's bright and works great! Thanks guys!
#16 | |
Most recently, I posted a question about how to keep my front turn signal sockets in the housings, only to learn (from a smart poster) that my turn signal housings were installed upside down :-) This forum is a great resource!! |
#17 | |
