07-15-2015, 11:11 PM | #1 |
Going back to stack axle on a 54 1/2 ton?
I have found a truck 54 1/2 ton that has a pacer front end currently----I understand it was a somewhat popular swap years ago.Regardless ---If I buy it I would rather go back to a stock straight axle with disk brake swap ect.
My question---what years front axle will bolt back on to the 54 frame----the pacer swap does not require frame mods and it SHOULD be a bolt on deal? Thanks chip |
07-15-2015, 11:21 PM | #2 |
Re: Going back to stock front axle on a 54 1/2 ton?
OK OK stock front axle what years fit? looks like 47-54 then 55 up is different?
07-16-2015, 08:25 AM | #3 |
07-16-2015, 11:24 AM | #4 |
Re: Going back to stack axle on a 54 1/2 ton?
Yep it has to be an AD front axle. If they got lazy and left the spring hangers in place at the back of the front springs it should be a simple swap with just a lot of grinding after you trim the Pacer front end off. Parts should be easy to find for the stock front end.
07-20-2015, 05:26 PM | #5 |
Got a picture of the truck? I sold my '54 which I put a Pacer front under about 15 years ago and I wondered what ever became of it. Mine also had a tilt front end on it and mini tubs in the bed when I sold it.
Thanks Rob
My '47 C.O.E build |
07-20-2015, 10:28 PM | #6 |
Thanks---truck was sold before I got there---it was in Davenport Iowa area.
