07-16-2015, 12:50 PM | #1 |
86 c30 dually lug nuts
I have a c30 with old alcoa rims on it. I will be swapping out for steel wheels. I did a search and didn't get a good hit, but I am wondering if there is any difference in the lug nuts between the two. Burned into my memory is an incident with a cousin with a bright yellow trans am, some freshly installed junkyard turbine wheels, a first drive, and myself sitting in the passenger seat as we slid down the highway on the slapper bars watching the rims go by since the tapered lug nuts didn't work like the sleeved ones the rims were supposed to have.
Attached is a pic of the rims
jjmorrse 86 C30 crewcab big dooley. 454- 400 |
07-16-2015, 01:16 PM | #2 |
Don't Crush em Restore em
Re: 86 c30 dually lug nuts
From what I remember alum. wheels almost always use different style lug nuts than steel wheels do. Alum. use a shank style and steel use the tapered.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
07-16-2015, 03:28 PM | #3 |
Dually aluminum wheels can be different. My old Alcoa's used acorn/tapered lug-nuts.
07-16-2015, 04:00 PM | #4 |
You would need a new ring for each wheel, and acorn lug nuts:
07-16-2015, 09:13 PM | #5 |
The dually I have acorn lug nuts with the rings and the nuts are 1 1/16 inch
09-15-2015, 10:16 AM | #6 |
Thanks, that helped me out. I appreciate it.
