Bench Seat Foam
I have 70 C10 and just ordered new seat foam for the bench seat. With the new foam in place, my head is 1 1/2 inches from the top of the cab. Has anyone had the same issue with this? If so, how did you fix it? Did you take a couple inches off the bottom? Any info would be helpful.
Re: Bench Seat Foam
You probably have a spring type seat and adding the full foam cushion will make it sit too high.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
Re: Bench Seat Foam
Are you talking about coil springs? The bottom has wires running fwd to back with extra support wire on the ends. The back has metal rods running side to side and bottom to top.
![]() Join Date: Nov 2004
Re: Bench Seat Foam
Wow, you're lucky... my head was barely 1/2" from the roof after mine (5'-8").
Drive the truck. The foam will "break in".
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Re: Bench Seat Foam
Lol, I wouldn't call it lucky. I still have a hard time getting my right leg under the steering wheel.
![]() Join Date: Dec 2013
Re: Bench Seat Foam
You might want to post a picture of your seat and the frame something sounds fishy .
Re: Bench Seat Foam
I plan to as soon as I get home. Thank you. It just doesn't seem right for my height. I'm 5'5''
Re: Bench Seat Foam
All I know is that there are two different bench seat frames and they don't reproduce the foam for the base seat. Only the full foam seat cushion is reproduced. The base spring seat doesn't use coil springs, but has these wavy wire spring rods running front to back. Then a burlap and thin foam cover. Kind of like the back rest has.
Re: Bench Seat Foam
I see. I do have the frame base with the wavy wire rods going front to back.
Re: Bench Seat Foam
Since you keep calling your truck a C/10 it may be a base build truck which had the spring seat. A "full foam seat" with a lot more foam and lower springs was an upgrade option and included with all optional trim levels. If you have a spring seat that had the thin padding your best bet is to find a full foam seat frame and build on that.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: Bench Seat Foam
The base bench seat with springs and thin foam.
Re: Bench Seat Foam
Here are a few pics. You can see in one how close the steering wheel is to the seat. Not sure why the pic rotated.
#13 |
Re: Bench Seat Foam
Well... That's the replacement foam fit . Once you install the seat cover it will compress that foam considerably . Where did you get that seat frame from ? The back rest looks like a later model style with no springs and just a foam pad
#14 |
Re: Bench Seat Foam
It was in the truck when I bought it a few years ago. Maybe I'll start searching for the correct one.
#15 |
Re: Bench Seat Foam
Looks like you have the full foam seat frame for the bottom. Can't tell on the back rest.
#16 |
Re: Bench Seat Foam
Hopefully I can make it work, or find the right one. It feels too weird sitting that high.
#17 |
Re: Bench Seat Foam
Well , I'm 6'2" and 240 , I have plenty of head room on the stock seats .
#18 |
Re: Bench Seat Foam
Thanks for rubbing that in, lol.
#19 |
Re: Bench Seat Foam
When I was trying to decide whether to fix my original worn foam or buy a repro full foam seat bottom, I noticed that the repro foam looks puffed up compared to original seat foam. Search thru old threads for pics and you will see what I mean.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
#20 |
Re: Bench Seat Foam
go to local upholstery shop and have regular old generic foam installed at a fraction of what the "factory correct" crap goes for
#21 |
Re: Bench Seat Foam
Well, I like that the foam is firm. So, I'm thinking that maybe the local upholstery shop will trim an inch or two off the bottom. Thank you everyone for your advice. I really appreciate it.
#22 | |
Re: Bench Seat Foam
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
#23 |
Re: Bench Seat Foam
Has anyone come across this? I purchased new bench seat foam and reupholstered with nice hounds tooth. Looks Great but foam is so thick I feel too close to the steering wheel for comfort.
#24 | |
![]() Join Date: Nov 2018
Re: Bench Seat Foam
Be warned you have to measure the factory brackets you have as there were 2 heights 5 and 7". They will lower your seat 2" and you lose your back and forth adjustment. I had that problem and a pair of these fixed it. https://squareup.com/store/full-cust...rackets-tall-2 |
#25 |
![]() Join Date: Feb 2019
Re: Bench Seat Foam
This link might help explain what seat foam will work for your truck.
http://www.americancushionind.net/pr...chevy-gmc-kit/ |
