Old 07-16-2015, 05:11 PM   #1
LT102
LT102's Avatar
Dana 60 Posi - Not being Posi
My Dana 60 posi is only applying power to the right tire. I bought this truck back after regretfully selling it 10 years ago. It was posi when it was sold and the previous owner assures me he didn't change anything, and I believe him. I pulled the left axle and all the splines look good. I have no idea what else to check. What do you think has broken.
LT102 is offline   Reply With Quote
Old 07-16-2015, 05:28 PM   #2
hugger6933
Re: Dana 60 Posi - Not being Posi
Clutches burnt out?
Springs worn or broken?
hugger6933 is offline   Reply With Quote
Old 07-16-2015, 05:41 PM   #3
LT102
LT102's Avatar
Is repair for that going to be really expensive?
Old 07-16-2015, 05:47 PM   #4
summitflier
summitflier's Avatar
The spool is really the only thing it could be. If the axle was broken it would fall out.
New spools are $400-$600. I personally would change the inner races and the bearings. If you get a shop to do the labor, could be a couple hundred more.
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 07-16-2015, 05:55 PM   #5
BLT gmc
Clutches are most likely excessively worn. Watch Toms differentials you tube video on rebuilding and tuning. He also is a great resource and parts supplier. Good luck
BLT gmc is offline   Reply With Quote
Old 07-16-2015, 06:54 PM   #6
65standard
65standard's Avatar
Make sure it is a true posi rear end first. Jack the rear up and spin one tire by hand and see if the other tire rotates in the same direction.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 07-16-2015, 10:20 PM   #7
Mike C
Mike C's Avatar
Most likely you have a TracLock and not a PowerLock or the Maximum Traction (Detroit) difff, but it could be any of the above. What does the SPID say?
Next, if it's 10 years since you last owned the truck, most likely the diff fluid could use a once a decade change. Pull cover. Take picture. Post picture in this thread. Then we can ID what your diff is and what you need to do.
Money has a TrackLock with worn clutches but will hold final judgement until we see pics.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-17-2015, 11:58 AM   #8
cdowns
cdowns's Avatar
anybody think after 40years or more it's just plain worn out??
Old 07-17-2015, 04:14 PM   #9
Mike C
Mike C's Avatar
Yes, That's what we have all mostly said. But to know for sure we have to know what it is. TrackLock=probably worn out. PowerLock maybe not... Maximum Traction diff then it's broken.
Old 07-18-2015, 02:08 PM   #10
vettedrvr
You will need to pull the diff cover and determine which center section you have. I'm betting it's a TruTrac and, if so, it is easily rebuildable. A clutch kit for it is available from Drivetrain Specialists for between $92.00 and $128.00 depending on which one you have. That's cheap considering a new one goes for $680.00.
vettedrvr is offline   Reply With Quote
Old 07-18-2015, 02:29 PM   #11
LT102
LT102's Avatar
I will try to open it up tomorrow and post a photo. Thanks for you help.
