Old 07-17-2015, 01:49 AM   #1
mjgord51
Shorting a Steering Column
I would like to know if any body has cut lets say about 3 or 4" out of a stock 72 auto trans steering column. Why might you ask would I want this done well like all of you know the D*m steering wheel is way too close and or my arms are too long and we all know the answer to that is BOTH are right. So lets here from some of you Engineering Genius's, I am pretty good with mechanical things so I am thinking the shorting area has to be done in the right place, I would think just under the shift lever housing and above the backup/ neutral safety switch would be the ideal spot right. what could go wrong? mjgord51
mjgord51 is offline   Reply With Quote
Old 07-17-2015, 07:46 AM   #2
chiefcfd
chiefcfd's Avatar
Re: Shorting a Steering Column
There are write-ups on collapsing the intermediate shaft under the hood. You can gain some room with that. Best choice would be a tilt column. Here is one article:
http://67-72chevytrucks.com/vboard/s...d.php?t=309895
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 07-17-2015, 08:33 AM   #3
Lattimer
Lattimer's Avatar
You don't need to shorten the column, you shorten the shaft between the column and the steering box. I have my column set so the part that necks up bigger is right against the dash.
Not a current pic, I have a different steering wheel now, but shows how far the column is pushed in.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 07-17-2015, 09:00 AM   #4
chopnchaneled
chopnchaneled's Avatar
What Lattimer said
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 07-17-2015, 12:07 PM   #5
sherm6413
Lattimer.... Any threads on how you accomplished this??
sherm6413 is offline   Reply With Quote
Old 07-17-2015, 12:19 PM   #6
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Try this. You'll be glad you did.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
