Old 07-17-2015, 09:45 AM   #1
flipper58
flipper58's Avatar
Part identification help-dumb question of the day
Ok, I usually do better than this at tracking parts on a dis-assembly, but I blew it on this one. Does anyone know what this is? I believe it came off/fell off while i was removing driver side fender?
Thanks,
Phil
flipper58 is offline   Reply With Quote
Old 07-17-2015, 09:55 AM   #2
jaros44sr
jaros44sr's Avatar
Originally Posted by jaros44sr View Post
Looks like spacers shim to me
jaros44sr is offline   Reply With Quote
Old 07-17-2015, 10:04 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Part identification help-dumb question of the day
Jaros is correct, it goes between the inner panel and the cab where the bolt with the large washer fits.... It helps to adjust the gap between the door and fender.
LockDoc
Leon
Old 07-17-2015, 12:03 PM   #4
michael bustamante
michael bustamante's Avatar
THANK YOU!!!!!!! I needed to ask the same question... thats what happens when you take a front clip off two years ago!!!!
1967custom
michael bustamante is offline   Reply With Quote
Old 07-17-2015, 12:14 PM   #5
flipper58
flipper58's Avatar
Great! Thanks a ton. My weekend is now already shaping up to be better.
Phil
Old 07-17-2015, 04:29 PM   #6
LockDoc
LockDoc's Avatar
Phil
No problem guys. You may not need it unless the gap between the front edge of the door and the back edge of the fender is too close.... To install it start the bolt first then holding onto the tab, hook the shim over the bolt from underneath. That is why it has the long tab on it.
LockDoc
Leon
Old 07-17-2015, 06:13 PM   #7
michael bustamante
thanks for the tip doc. i was wondering about that. im sure ill need em. my gaps have been real close so far.
sorry for the hijack flipper
1967custom
Old 07-30-2015, 07:13 AM   #8
flipper58
flipper58's Avatar
Yes, thanks doc for that tip. Sorry about the late reply.
Old 07-30-2015, 08:09 AM   #9
LockDoc
LockDoc's Avatar
No problem. Glad I could help....
LockDoc
Leon
