Old 07-17-2015, 03:36 PM   #1
72hoopti
ZZ4 Head Gasket
Gentlemen-I have blown my SECOND head gasket in my zz4. Does anyone have access to instructions to replace head gaskets for the zz4? The motor has 38k on it and Im not paying another 1500 bucks to have it replaced.
72hoopti is offline   Reply With Quote
Old 07-17-2015, 04:38 PM   #2
leftybass209
leftybass209's Avatar
Re: ZZ4 Head Gasket
The procedure isn't special for a zz4 as opposed to any other sbc. A quality head gasket and proper torque sequence should take care of it. Its good practice to replace both gaskets together as well because different thicknesses change the compression slightly as well.
Do you know why you've been blowing head gaskets?
leftybass209 is offline   Reply With Quote
Old 07-17-2015, 08:38 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
Re: ZZ4 Head Gasket
I would check the head (s) with a straight edge to be sure that they aren't warped. Due to your previous trouble I would take the heads and have them resurfaced. They can do this without taking the heads apart, and the cost should be minimal. Even if the surface is true, it might be too slick to get a good seal. What gasket did you use previously? Fel Pro makes an MLS gasket that's hard to beat.
WIDESIDE72 is offline   Reply With Quote
Old 07-17-2015, 08:40 PM   #4
67 chevelle
67 chevelle's Avatar
Re: ZZ4 Head Gasket
arp studs are probably a good idea also
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 07-17-2015, 09:24 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
Re: ZZ4 Head Gasket
To each his own, but seems like overkill on a non boosted engine. Keep in mind that studs may make in truck head removal difficult if not impossible. I know they do on a big block in a first gen camaro!
