Old 07-17-2015, 04:10 PM   #1
weider1717
exhaust manifold to exhaust pipe torque value?
I torqued my original cast iron manifolds to the block per torque values I found on the net 26ft lbs on the 2 inner bolts and 20ft lbs on the outer bolts.
Question - Is there a torque value for the exhaust manifold STUDS to the exhaust pipe? I can't find any online this is for a 1987 1/2 ton silver ado model v10. Maybe the manifold to pipe typically doesn't have a torque value? but surely it does not everyone has common sense and I like things to spec.
it just says 2 inner bolts 26ft lbs all other bolts 20ft lbs think that just refers to manifold to head though.
I'm by the book so if there is a value I would rather just torque to spec. thanks
weider1717 is offline   Reply With Quote
Old 07-17-2015, 06:44 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: exhaust manifold to exhaust pipe torque value?
That's one I'd rather do by feel and get it gudentite. If you try taking it to a specific number it might snap and give you more grief than it's worth. Snug it up tight as you feel comfortable - if it don't leak you are good. I've got a manual and can look it up if you want though.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-17-2015, 07:52 PM   #3
weider1717
If you wouldn't mind looking for me I would appreciate it. Remember this is on the bottom end where the manifold / studs mate up to the exhaust pipe. the manifolds are already in place and torqued to spec to the heads.
need to know what torque to put on the nuts I have all new hardware, spring, nuts, studs so hopefully won't have to touch this for awhile.
Old 07-18-2015, 10:56 AM   #4
68Timber
68Timber's Avatar
17 ft/lbs. I wouldn't have guessed it that low. I forgot you'd restored your manifolds. Nice work and beautiful truck.
John
74 Honda Z50 build
Old 07-19-2015, 09:20 AM   #5
weider1717
Thanks bruiser!
I'm a bit confused though I remember the spring load tension (by looks) on the original springs when I removed them and took note of how much threads were exposed etc.
before your response I set my torque wrench to 5ftlbs and never got the "click" and I was about where I marked them to be before I removed them.
I'll take it for what its worth and torque to 17ftlbs though and see how things look.
Old 07-21-2015, 10:23 AM   #6
cadillac_al
I thought this was going to be a thread about a broken stud from a cheap torque wrench. I guess you lucked out so far because I read about it all the time. I did it once myself in my younger days. You wait for the click and the bolt/stud goes snap. I think some of these torque values are just to give you an idea how tight to crank on it with your wrist. I have gone on rants in the past about cheap clicker torque wrenches. I still rebuild engines with my old old beam type torque wrench and it hasn't failed me yet.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 07-21-2015, 11:42 AM   #7
68Timber
68Timber's Avatar
Based on a Car Craft or Hot Rod article on torque wrenches, I picked up a HF $10.00 model - according to their testing it was as accurate as any of them. My Craftsman model died recently, and a buddy was over helping me put heads on a motor. He brought his 30 yr old Snap On. Out of the box, that cheap HF wrench torqued to the same spec that Snap On wrench did. I don't know how it'll hold up though, I kinda feel like a need a more expensive one to rely on.
John
74 Honda Z50 build
