09-07-2003, 10:18 AM | #1 |
any bagged pro-streeters out there?
i was thinkin......it seems like theres a split between the bagged show guys and the tubbed go type guys. wondering if anyone out there has a tubbed/blown truck that also will lay frame on bags? ive personally never seen a truck like this. seen some low prostreeters but never seen one lay frame...
09-07-2003, 11:22 AM | #2 |
my friend has one localy. it has a rear end setup that i haven't seen before. its a bagged ladder bar setup. its pretty tight. i think we have some pics of it in my freinds digi cam, i'll try to get them. its still under construction but he drives it.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
09-07-2003, 10:09 PM | #3 |
Project92 SWB stepside
My truck is going to be a Phantom dually which means I am using a stock dually bed and putting a set of 33x 19.5 MT's under it. It uses the stock axle size. I am going to hopefully be laying rocker and will be bagged with a 4 link rear and notched front crossmember. I have a SBC 406 that puts out 450 hp without aluminum heads. Once I switch the heads I should get over 500!! But it is not blown!! That would be cool.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
