Old 09-07-2003, 12:24 PM   #1
Keep on Trukin
Help!
I need help my truck keeps stopping and i have just put a new fuel pump in it, plus carb kit, help! It starves for fuel. Its a 1967 GMC with a straight 6, keep in mind its been sitting for a few years.
Keep on trukin
Keep on Trukin is offline   Reply With Quote
Old 09-07-2003, 12:30 PM   #2
SLS
Finish the'71..or bust!
SLS's Avatar
Did you change the fuel filter too?
Is it delevering fuel at the end of the line where it attaches to the carb?
Is it possible that the fuel line is routed too close to a heat source (like exhaust manifold/ headers) thus causing a Vapor Lock condition in the supply line?
Just some things to check.
Also, it is possible that the new pump, or carb, is bad...right out of the box...so a little tracing back of the fuel delivery system is necessary. I would unhook the fuel line at the carb and make sure the pump is squirting fuel first.
Good luck.
SLS is offline   Reply With Quote
Old 09-07-2003, 03:24 PM   #3
nu2-72
Pull the coil wire and crank into a milk jug. You don't want a fire.
May be stuff in the tank sucking over the screen.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 09-07-2003, 03:35 PM   #4
miket
miket's Avatar
may want to post this in engine and drivetrain too!!!
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
