carb problems
To start:
I have a 1977 Chevrolet C10 with a 250 and a monojet carburetor. Basically, i have to constantly bump up the idle with the idle adjustment screw because it will slowly drop idle speed over time until it dies every time i put in the clutch. I've adjusted the idle mixture screw and the idle speed adjustment and dialed it in, but everytime after 20-30 minutes of driving my idle speed will drop. any suggestions? thanks |
![]() Join Date: Oct 2014
Re: carb problems
I've been having the same issue with mine, 86 Chevy. I've opted to get a new carb, got tired of adjusting screws every time I drove it. Just ordered the new carb last night, so I'm anxious to get it and to get it installed.
Re: carb problems
try stretching the springs out a bit so there is more tension.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
Re: carb problems
what springs are you referring to?
Re: carb problems
Idle mixture, idle speed, and just about any adjuster screw on a carb has a spring on it. The spring loads the threads enough to hold adjustment.
as in this pictured Q-Jet.
Re: carb problems
Oh, alright thank you. I will definitely give that a shot and report results.
Re: carb problems
I would put a dab of High Tack on the threads. If you don't have any High Tack and don't want to buy it, I'll bet Chinese sweet and sour sauce would work; seriously that stuff is super sticky. I had a carb that wouldn't hold an idle adjustment and that's what I planned to do but never got around to it.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Re: carb problems
Problem solved! Ended up pulling the screw and putting thread sealer, and ran it in tight to the whole adjustment solenoid thing, so now my idle adjustment is made by turning the solenoid. Works well, and holds idle.
