Old 07-19-2015, 01:25 PM   #1
HONDAWASAKI
difference between '67, and '68 turn signal buckets
Hello every one, what is the difference in '67, and '68 in how the turn signal buckets mount? I have a '67 that only came with one bucket, and I bought a set of "'67-'68" turn signal assemblies and apparently the '68 is different, and these are '68 only. The '67 mounts with studs on the bottom, and '68 mounts with studs on the back I guess?
So my question is, does the '68 have the same grille, and use an adapter bracket? Or does it have a different grille, and different turn signal buckets? Or are these turn signals completely the wrong ones?
Thanks in advance.
HONDAWASAKI is offline   Reply With Quote
Old 07-19-2015, 01:40 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: difference between '67, and '68 turn signal buckets
I think you have the wrong ones. The 67-68 should be the same. The ones with the studs in back are step van or bigger series truck. Alot of the wrong ones are on e-bay listed as pickup ones.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-19-2015, 01:43 PM   #3
HONDAWASAKI
That is exactly where I got them, ebay. I was just thinking the same thing, they must be for a van. Just one more thing I wasted money on. Thanks.
Old 07-19-2015, 03:11 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
The 2-pin connectors are slightly different also. '67 turn signal connectors have one blade vertical and one blade on an angle. '68 connectors have one blade vertical and one blade horizontal. [Or was it the other way around?] I just spliced the plugs onto the harness and it was fine.
The grilles are the same. Difference is in the trim rings.
I hit a deer with my '67 Suburban. I got another grille from a junkyard '68. It went right on. Only difference was in the connectors.
Old 07-19-2015, 07:25 PM   #5
HONDAWASAKI
Thanks, the info is very helpful. The more I learn about my '67 the more unique it gets.
'67 C10 shortie.
Old 07-20-2015, 03:51 AM   #6
'68OrangeSunshine
Of course you know that the "Parking Lights" go out when you select Headlights ON. That is not a short. They do not stay on with the headlights like the '68s and later.
I had a '68 first and that got me until someone told me it was normal, not broken.
