Old 07-19-2015, 09:50 PM   #1
HuntinNut
Motor Mount Perches For 66 W/85 Disc Brake Conversion
So I finally got the disc conversion done on the 66 I'm doing a frame off on and don't have the correct perches for my sbc. It's a 66 with the complete front crossmember and discs from a 85. What perches do I need to be able to use the style of motor mounts from the 85 ? I've seen it on here before, just can't find it now
HuntinNut is offline   Reply With Quote
Old 07-20-2015, 01:07 AM   #2
Captainfab
60-66 Nut
Re: Motor Mount Perches For 66 W/85 Disc Brake Conversion
If you want to use the style of engine mounts used on the '85, you will need the frame brackets (perches) from a '73-'86 C20, C30 or a '87-'91 R2500, R3500.
Old 07-20-2015, 08:42 AM   #3
Mathew21
Mathew21's Avatar
I was going to go this route in my 66' with my 5.3 swap. I have a set of frame perches from a 78' C20. But it wasn't just a bolt and go. I would've had to trim my frame some. I ended up using my stock perches. I'm going to list the 78' C20 perches in the classifieds in the next few days.
This quote below was taken from Captainfab from this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=204885
If you want to use the '73+ motor mounts, you will need a pair of frame brackets (perches) from a C20. They fit the frame height better than the '73+ C10 brackets. You will still need to trim the top flange of the frame back about 1/2" or so.
Or do as Tx Firefighter recommended, get a set of '68-'71 big block mounts
It only has original paint once
Mathew21 is offline   Reply With Quote
