Old 07-19-2015, 09:55 PM   #1
jimmystepper
Removing cab on 66 stepside
Hi, new member here, thank you for allowing to be a member. just got my '66 stepside and want to remove the cab from the frame. However, I'm lazy can I remove it with the front sheet metal (fenders and grille etc. still attached) I don't want to damage anything. I tried searcing the forum but came up with nothing. thanks for your help.
jimmystepper is offline   Reply With Quote
Old 07-20-2015, 11:43 AM   #2
Figuarus
Figuarus's Avatar
Re: Removing cab on 66 stepside
it's possible, but separation of the front clip is definitely easier.
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 07-20-2015, 07:44 PM   #3
jimmystepper
Hi Figuarus, thanks for replying, can I remove the fenders/grille/ radiator filler as a unit ? it sure would make it a lot simpler to do. how about with the hood? Thankyou, Jimmy
Old 07-20-2015, 07:51 PM   #4
Figuarus
Figuarus's Avatar
yes you can separate the fenders and the course support as 1 unit. The hood will have to come off on its own. Once you have the front clip off, make sure to save all your hardware, and have someone help you lift it off the frame
Old 07-20-2015, 07:57 PM   #5
jimmystepper
Thanks again, jimmy
1966 chev. short stepside
