Custom Truck Lover!
Need parts help for power steering conversion
I bought CaptFab's adapter plate. I know I need 73+ gear box and pitman arm. I will be using an A/C compressor too. My question is what is the correct pulley configuration for the 350 sbc set up? If you know, please be exact. Pictures would be great too. Thank you ahead of time.
Squarebody guy Last edited by YOLO; 07-20-2015 at 10:08 PM. |
Custom Truck Lover!
Re: Need parts help for power steering conversion
anyone???
Squarebody guy |
![]() Join Date: May 2005
What engine are you working with?
Custom Truck Lover!
350 out of a 70 Camaro
60-66 Nut
![]() ![]() Join Date: Mar 2007
If you are still using the long water pump that came in the Camaro, then to simplify it you will need pulleys and AC brackets for a '70 Camaro. I'm not sure if the pulleys on the Camaro engine will have the extra groove for the AC belt. Maybe if you post pics of what you have, it will be easier to help.
I took the box with Pitman arm and shaft from a 67 and it worked OK, along with the bracket modification.
For the pulley set up probably the easiest might be to cruise the junkyards to find a compatible part. |
#7 | |
Custom Truck Lover!
Squarebody guy |
Custom Truck Lover!
Im ready to stab in the motor and trans.
Squarebody guy |
Custom Truck Lover!
Can anyone look at my pictures and just tell me if I need to use all 70 Camaro pulley system? I know if will use a 73+ gear box and pitman arm.
Squarebody guy |
If it worked in the camero it will all work in your truck. except that that the fan location will not be right if you decide to run a stock type shroud. use the 73 p/s box and pitman arm
ron |
60-66 Nut
There's no reason the '70 Camaro PS pump and even an A/C compressor and it's brackets won't work. To add A/C you will need a different water pump pulley and possibly a crank pulley. I'm really not sure on the pulley needs for A/C on a long water pump small block.
In case you do not know, all trucks '72 and earlier originally came with short water pumps. Consequently certain factory application parts will not work quite right. You will also have to move your alternator wiring to the passenger side.
