07-20-2015, 02:08 PM | #1 |
cracked steering wheel
hi has anyone got any tips on how to repair a cracked steering wheel and what to use ie epoxy putty
07-20-2015, 03:32 PM | #2 |
It's Better With Nitro
Re: cracked steering wheel
I use PC-7 two-part epoxy that, when mixed correctly, sets up to be the same hardness as the original steering wheel material. I would recommend using a small die grinder to make a V-channel in the crack all the way down to the steel. I recently reduced the diameter of my steering wheel and had to do a few repairs to some cracks on the lower ring and around the hub at the same time:
07-20-2015, 04:37 PM | #3 |
"Where were you in '62?"
Home - Steering Wheel Restoration - Steering Wheel Repair - Tips From Eastwood
Steering Wheel Restoration http://www.eastwood.com/steering-whe...-from-eastwood Steering Wheel Restoration Tips Episode 119 Autorestomod https://www.youtube.com/watch?v=ej2k_xoxjIY
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
07-20-2015, 07:53 PM | #4 | |
http://67-72chevytrucks.com/vboard/s...=474456&page=9 |
