Old 07-20-2015, 07:27 PM   #1
TKCR
TKCR's Avatar
Engine Room Help, What can I Remove?
So I'm in the process of putting on new headers, new carburetor, valve covers, wires & plugs. The one thing I hate is these vac lines laying across the valve covers. Can I remove all this or relocate somehow?
Old 07-21-2015, 01:48 PM   #2
TKCR
TKCR's Avatar
Re: Engine Room Help, What can I Remove?
Anyone?
Old 07-21-2015, 02:51 PM   #3
rich weyand
rich weyand's Avatar
I don't even know what half of that crap is. I have manifold vacuum to: 1) PCV valve from the center port of the Edelbrock to a PCV valve on the driver's side -- that has to stay; 2) from the back side of the intake manifold to the TH350 -- that has to stay; 3) from the back side of the intake manifold to the power brake booster -- that has to stay; 4) from the driver side front of the Edelbrock to the distributor vacuum can -- that has to stay; and 5) a T in number 4 to the thermac to run the air door -- that has to stay.
All the rest of that, including the evap canister can go, but you need more info from someone else on what to do once you take it off.
BTW, there should not be anything connected to the ported vacuum on the Edelbrock, the passenger side port on the front. That's wrong.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 07-21-2015, 03:09 PM   #4
TKCR
TKCR's Avatar
Rich, you just live over in Indiana. Maybe you can give me a hand and teach me thing or two about engines. I have to admit, I really don't know a whole lot, but I want to learn.
Old 07-21-2015, 05:06 PM   #5
rich weyand
One thing you didn't do is identify make, model, year, engine of our truck.
Rich Weyand
1978 K10 RCSB DD.
Old 07-21-2015, 06:19 PM   #6
TKCR
TKCR's Avatar
86 Chevy C10 Silverado 305
Old 07-22-2015, 08:24 AM   #7
bnoon
That's the vapor canister. People remove it all of the time, though it doesn't really do much of anything except keep gas fumes from going directly into the atmosphere. It's not hooked up correctly in your pictures anyway. The vent line from the canister that connects back to the tank should go to the carb vent line, the rest simply eliminated. I can't remember if the Edlebrock has a vent line, if not, just run a vent tube up the fender and put a vent cap on it (not a plug).
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 07-26-2015, 06:20 PM   #8
TKCR
TKCR's Avatar
Ok, so this is what I came up with. It doesn't seem to be causing any issue, just idleling. So let me know if everything looks like it is hooked up right. I left the fuel vacuum hooked up to the vapor canister, everything else I took off and capped.
Old 07-26-2015, 06:23 PM   #9
TKCR
TKCR's Avatar
I also put new plugs & wires with wire loom in. New headers & valve covers.
Old 07-27-2015, 12:34 AM   #10
rich weyand
Vacuum advance is still on the wrong vacuum port on the front of the Edelbrock. Should be connected to driver's side port, and passenger's side port plugged off.
Rich Weyand
1978 K10 RCSB DD.
Old 07-27-2015, 12:47 AM   #11
mrolds88
First thing I would remove is the fuel line setup. Use a steel line between the fuel pump and carb. Reason being is that if hose either gets rubbed or deteriorates, it will spray fuel.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-27-2015, 12:57 AM   #12
TKCR
TKCR's Avatar
That line goes to the EGR valve, is that correct? The EGR valve is back by the distributor?
Old 07-27-2015, 01:00 AM   #13
TKCR
TKCR's Avatar
I will as soon as I get the new carb in. That's my next project. Just waiting on a few parts to be delivered.
Old 07-27-2015, 01:13 AM   #14
TKCR
TKCR's Avatar
Rich I'm sorry if I'm asking dumb questions, but I'm still learning. What is the round metal part in this photo that the 3/8" hose is connected to. I don't what it is or what its for. It had all the vapor canister lines going in and out of it.
Old 07-27-2015, 01:29 AM   #15
rich weyand
That line should go to the vacuum advance can on the distributor, but the VA connection belongs on the other side of the carb.
Rich Weyand
1978 K10 RCSB DD.
Old 07-27-2015, 01:45 AM   #16
TKCR
TKCR's Avatar
Is this what your calling the vacuum advance? So this line goes to the drivers side port on the carb?
Old 07-27-2015, 10:41 AM   #17
rich weyand
Yup.
Rich Weyand
1978 K10 RCSB DD.
Old 07-27-2015, 10:45 AM   #18
TKCR
TKCR's Avatar
Yup.
Thanks Rich, for all your help
