Old 07-20-2015, 09:09 PM   #1
farmall
farmall's Avatar
81 K30 T400 only shifts via the Gov.
I was cruising along slowly when it would no longer shift without winding her out. Put a new Vac Mod and new rubber hose ends on, tested for Vac at the Mod and pulled the valve out. All looks good and within spec. Any ideas?
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 07-21-2015, 03:06 AM   #2
Chevy_mud_truck
Chevy_mud_truck's Avatar
Re: 81 K30 T400 only shifts via the Gov.
I had one doing close to the same thing it was the switch on the pedal that works the passing gear going bad
Chevy_mud_truck is offline   Reply With Quote
Old 07-22-2015, 06:53 AM   #3
Good to know. My son's CUCV is doing the same thing after a rebuild and we replaced the module.
Old 07-22-2015, 10:03 AM   #4
farmall
farmall's Avatar
I pulled and inspected the Gov and the valve moves freely, disconnected the kick down wire, test drove with the same result. Next I am going to swap Mod valves with another transmission.
Old 07-22-2015, 08:28 PM   #5
farmall
farmall's Avatar
I backed the adjustable modulator all the way out with no results.
I placed a piece of cellophane on the bottom of the PCV valve and reinstalled it with no results. The only vac lines are PCV, distributer, and the vac mod.
I tested the integrity of the metal/rubber vac line from the manifold including the modulator and it holds 20lbs fine.
Next when the rig cools down I am going swap the modulator valve with one from a spare TH400.
Old 07-22-2015, 10:38 PM   #6
farmall
farmall's Avatar
Swapped the valve, no change.
Looks like I get to drop the pan. Hopefully something will fall out and hit me in the head so I can get this fixed.
Old 08-15-2015, 08:11 PM   #7
farmall
farmall's Avatar
Dropped the pan and the detent/kickdown solenoid was hanging by its wire. The welds that attach the 4 feet to the bolt up plate failed. I have one ordered and I hope this fixes it.
Old 08-19-2015, 11:26 PM   #8
farmall
farmall's Avatar
Smile Re: 81 K30 T400 only shifts via the Gov.
It shifts now
