Old 07-20-2015, 10:54 PM   #1
lucusbumanlag
1959 Chevy Apache front shocks location
I am building a bagged 1959 Apache that has a 2nd Gen Camaro front clip right now. Ive installed the front bags into the stock upper and lower control arm of the camaro already. My problem is im not sure where to install the front shocks at. I was planning on welding some tabs sticking out from the frame behind the control arms then welding tabs on the lower control arm side thats closer to the fire wall side to mount the shocks. Thats just what i might try out. Just wondering what you guys think?
Also If anyone else is running this setup or something close to this setup can i get some pictures of where you mounted your shocks. That will really be helpful.
Or if anyone knows of a company that sells premade mounting brackets that i can just weld on for this application.
lucusbumanlag is offline   Reply With Quote
