Old 07-20-2015, 11:14 PM   #1
cheap
lowering help
I'd like to drop my 77 C10 4" in front and 6" in back. Will this require a flip kit, and if so do i need new parts to do that? to drop the front, what should i do and what parts should I get?
thanks
cheap is offline   Reply With Quote
Old 07-20-2015, 11:23 PM   #2
UKNOWME
UKNOWME's Avatar
Re: lowering help
Spindles, coil springs, flip kit and shackles if not low enough.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 07-21-2015, 09:24 AM   #3
SCOTI
SCOTI's Avatar
Re: lowering help
It can be done w/o a flip kit but it's much harder to do & more costly. Keep it simple & do a flip kit. I would recommend Bell Tech or Western Chassis because they have a beefier flip bracket vs some other options.
A flip kit has the required brackets, new u-bolts, & shock extenders to extend the lower shock mount & decrease the angle (it changes once parts start moving around).
Drop spindles (Bell Tech, Western Chassis, McGaughys).
Same companies for drop springs or you can cut 1-coil off the current units if you're okay w/the current ride & the truck sits relatively even (measure before starting anything). Add some good quality shocks.
Once again... I highly recommend measuring all 4 corners on a level surface & record it down in a notebook before starting.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-21-2015, 01:02 PM   #4
Tom
driving is in my blood
Tom's Avatar
Re: lowering help
Flip kits don't come with shock extenders, at least not the western chassie kits I've bought in the past.
Old 07-21-2015, 01:26 PM   #5
SCOTI
SCOTI's Avatar
Re: lowering help
Thanks for the correction....
I would recommend buying them then since they don't come w/the kits.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
