Old 07-21-2015, 11:40 AM   #1
Jemo
Improving the ride? Anyone use coil overs?
I have a Mustang 2 front end on my '59. It rides fair, kinda squeaks a bit. I guess if I could go back I would've put air bags on it to ride great but not sure I want to go back and do that now. I'm wondering if a good quality set of coil-overs would be worth the money? I'm looking for ride quality, not handling or a stiffer ride. Does anyone here have a set of RideTech or QA1 coil overs they can tell me more about?
'59 Big Window Fleetside
Jemo is offline   Reply With Quote
Old 07-22-2015, 09:13 AM   #2
oldman3
oldman3's Avatar
Re: Improving the ride? Anyone use coil overs?
Jemo, I switch over to QA1's on my 50 pickup and I very happy with the outcome. You can check out what I did in my build thread starting on page 23 post #567. Any question let me know...Jim
oldman3 is offline   Reply With Quote
Old 07-22-2015, 12:58 PM   #3
solidaxel
solidaxel's Avatar
I ended up with a lighter Mustang ll coil spring and a Bilstine shock for the Mll stock arms and my ride has 65K and it rides and handles great
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-22-2015, 01:12 PM   #4
Jemo
I read Jimbo's post in his build thread and think I'm having the same issues. TCI tells me the coil springs in my truck are 375#. I also have a pinched upper ball joint boot. I called TCI and they said the pinch will go away as the coils start to settle but meanwhile I have a bad boot. I called QA1 and they suggested the same thing they did as Jimbo - a 700 lb spring. He was surprised the spring in the kit is 375#.
Old 07-22-2015, 07:36 PM   #5
oldman3
oldman3's Avatar
Jeff, just a side note, my name is Jim. Jimbo is a friend of mine I built the 67 for. As a group we need some pics, so we can all agree on what design you have. Also what type of spring you currently have. A stock coil spring for MII, coil-over spring, long or short will all make a difference...Jim
Old 07-23-2015, 11:44 AM   #6
_Ogre
_Ogre's Avatar
if your mustII was made for coil springs it would not be an easy conversion to coil overs
i have a fatman mustII that started squeaking after 5000 miles, at 12,000 miles the bushings were worn out
fatman recommended no lube on the rubber bushing as they were graphite impregnated
when i re-bushed my front end last year i used energy products grease and have no squeaks in 10,000 miles
shop air compressor timer
Old 07-26-2015, 07:46 PM   #7
mod50
I have 50AD with MII front end and QA1 coil overs made for MII coil spring setup. Ride is really nice, and with a decent sway bar the handling is also good. I found vehicle weight info on Ride Tech web site plus recommended spring rates. I used that to pick springs, don't remember what they were and can't find receipt.
mod50 is offline   Reply With Quote
