Old 07-21-2015, 11:41 AM   #1
mjh1965
mjh1965's Avatar
How many teeth please help
Hi I have just got a 350 engine for my truck . The engine code is 14093638 according to my search I have found out that it's a
OHV,RWD,PFI/TBI,roller lifters, center bolt valve covers high swirl intake ports
With a single rear seal
My question is I am removing the fly wheel and need a flex plate as I am fitting a TH350 auto box . I have counted the teeth on the fly wheel and there is 168 teeth but looking on the net I also found this
Now my starter bolts are inline so that contradicts the thread above . Do I order one with the same teeth as the fly wheel for an engine with a single rear
Thanks for any help
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 07-21-2015, 12:41 PM   #2
PGSigns
PGSigns's Avatar
Re: How many teeth please help
If it has 168 teethe you need one for the one piece rear seal with a 168 teeth.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-21-2015, 11:19 PM   #3
Pappyx3!
Pappyx3!'s Avatar
Martin,
Is your concern the correct starter to flywheel combo?
Check your starter mounting on the engine block, a lot of Gm blocks were drilled for both the straight and offset starter mounts.
The post from the forum you showed is generally correct. However there are straight mount starters that will fit either tooth count flywheel. Most of these I remember had 3 mounting bolt holes.
Got info on the year of the truck the engine came out of?
Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline   Reply With Quote
Old 07-22-2015, 01:39 AM   #4
mjh1965
mjh1965's Avatar
Originally Posted by Pappyx3! View Post
Martin,
Pappyx4!
Thanks yes the starter thread is what had concerned me I will check for three bolt holes . If the flywheel is 168 I guess I will get a 168 flex plate for a single seal . I don't know what year vehicle the engine came from as it was installed into a 65 c10 in the states before it was imported into the UK
MY BUILD THREAD:
Old 08-03-2015, 03:30 AM   #5
mjh1965
mjh1965's Avatar
Well with the flywheel off and counting the teeth I now know I need a 168 tooth flex plate
All I can find out about the engine is its made from 1988 to 1994
I know my engine has a single rear seal so that narrows it down
I am fitting a th350 and when I look up flex plates they are asking if its internal or externally balanced my torque converter has the number 1362650 stamped on it .
Are they all interchangeable or is there a way of telling the difference many thanks in advance for any advice
MY BUILD THREAD:
Old 08-03-2015, 11:52 PM   #6
crazy longhorn
Fabricate till you "puke"
Martin, the engine that you have (1 pc seal rear main), will have a weighted flex or flywheel, how ever the balancer on front is neutral balance. Its hard for the parts guys to "chase', what is not in the computer? The vortec is a truck engine.....look for the date code on the block, to narrow it down...(that way, the parts house computer can dig up the proper part). Hope that helps...longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-04-2015, 03:15 AM   #7
mjh1965
mjh1965's Avatar
Thanks Longhorn I started stripping the engine last night ready for paint as it's now on the stand . These are the numbers I have found .
On the front behind the water pump on the flat machined part is V1024UZB
On the rear above the oil filter on a machined flat part is CME138359
On the back of the block is in cast is 14093638
If any body can tell the year and what it came from that would be great
MY BUILD THREAD:
Old 08-04-2015, 09:48 AM   #8
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Martin, I've recently been researching the internal/external balance question in preparation for buying a vortec crate motor and, while there's lots of discussion on the forums, most is confusing. to keep it simple I decided to go with GM's use of the terms when describing their crate motors. bottom line is that, for a 350 anyway, 1 piece rear seal engines are called externally balanced. 2 piece rear seal engines are referred to as internally balanced. it has to do with the small balancing flange on the flywheel/flexplate end of the crank. this flange is missing on the 1 piece seal motor. apparently GM considers the flange to be part of the "internal" balance even though it is "outside" the seal and pan when assembled. the 1 piece crank requires the balancing to be on the flywheel/flexplate. thus "external" balance
lots of starters come drilled with 4 bolt holes to fit either diameter wheel. btw, for future reference, you don't have to count all those teeth, the 168 tooth wheel will be 14 inches in diameter, the 153 tooth is 12 3/4" IIRC
also, from the mortec site (http://www.mortec.com/castnum.htm): "14093638...350...87-95...2 or 4...Roller or flat tappet cam, one-piece rear seal"
I don't think that's a "vortec" try checking the cylinder head casting number
Larry
fleetsidelarry is offline   Reply With Quote
Old 08-04-2015, 01:08 PM   #9
fleetsidelarry
Senior Car Nut
Martin, in addition to knowing the type (internal/external) and teeth/diameter talked about in the previous posts, since you already have the converter you'll need to know the diameter of the converter bolt circle. common would be 10.75, but it could be 11.5 or 10.5.
Larry
