Old 07-21-2015, 12:47 PM   #1
Goldengophersax56
Goldengophersax56's Avatar
Radiator Question
I'm looking into radiator options for my 56 GMC. The truck will be running a SBC 350. I am hoping to just have the stock one boiled out and fixed up. If it needs it, re-cored. Should that be a big enough radiator?
Goldengophersax56 is offline   Reply With Quote
Old 07-21-2015, 02:47 PM   #2
fisherman420
Re: Radiator Question
A good clean original radiator will work fine for a stock to mild 350 with a good fan and shroud. However....., If your rad needs to be re-cored I would buy a new champion unless you want to keep the original look. You can get a brand new one with built in trans cooler for under $200.
fisherman420 is offline   Reply With Quote
Old 07-21-2015, 03:34 PM   #3
OrrieG
OrrieG's Avatar
I got one out of a big truck (1.5 ton and larger) that is in good shape. 1" thicker and deeper, bolts up to the small truck core support. I run a shroud and have never had an over heating problem, even with the stock 6 cylinder one.
OrrieG is offline   Reply With Quote
Old 07-22-2015, 12:58 PM   #4
Goldengophersax56
Thanks guys. Also, thanks for not jumping down my throat for posting this on the wrong page. I just realized that I accidentally posted it here...
I'm going to throw it on the main one just for the heck of it.
Thanks again!
