07-21-2015, 04:13 PM | #1 |
Anyone willing to provide the following measurements for GMC Dash (pic included)
Starting the design phase of a replacement GMC dash bezel. I'll either be printing one, or milling it from block plastic.
I don't have access to one currently or else this would be a lot easier . Would anyone be willing to provide the 1-8 measurements for me based on the pic below? #8 is a depth measurement. These should get me in the ballpark so in the next few weeks I can route these from cheap wood for test fitting/adjustment. 1. Inside measurement bottom to beginning of top curve. 2. Inside height measurement at end of curve. 3. Inside height center. 4. Outside height, edge to edge. 5. Inside width bottom. 6. Inside width start of curve. 7. Inside width top where curve ends. 8. Depth If anyone in the Portland area has one I could borrow for a couple of weeks that would also work swimmingly . Cheers all! |
07-21-2015, 04:38 PM | #2 |
Check The Champ, Demonstrator
Re: Anyone willing to provide the following measurements for GMC Dash (pic included)
I have one to mail to you if your interested. Has been in the garage for years.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
07-21-2015, 04:42 PM | #3 |
Sent you a PM.
07-22-2015, 01:09 AM | #4 |
60-66 Nut
I can get those measurements tomorrow if you still need them.
07-22-2015, 03:02 AM | #5 |
Is there a reason why your going to spend all that time building one when you can buy an aluminum one instead?
Link: http://www.boeseengineering.com/Shop...3-3-8-quot-spe For anything different I think they charge $250 for it. I wanted three holes like stock with two smaller ones on each end.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
07-22-2015, 09:31 AM | #6 |
I made mine. It's made frome the stainless trim for a 88-98 chevy truck. (the aftermarket stuff for the bottom) Hear is the link. http://67-72chevytrucks.com/vboard/s...d.php?t=516023
1964 |
07-22-2015, 12:38 PM | #7 |
Someone is actually mailing me a spare one they have, so I should be able to take measurements myself in a bit. Thank you though and will definitely hit you up if I run into a snag of some kind.
07-22-2015, 12:43 PM | #8 | |
@64shortbed - that looks great! Did you have an original trim that you worked with, or if not, did that come from something else? Ultimately I'm looking to make a solution where if someone staring at a giant hole where gauges would be, they could use something like this as a replacement. Aside from that, I'm doing it to learn new design skills, and exercise the CNC router I should be receiving soon . |
07-22-2015, 12:43 PM | #9 |
If Canada and the States don't go to war, you should have it next Friday. lol. Thank you for your donation to Zane's Ride.
CNC router, this I'd like to see.
07-22-2015, 12:46 PM | #10 |
Thanks again! I'm in contact with Zane's mom via Facebook and getting the paypal info to donate . Cheers!
