Old 07-21-2015, 06:57 PM   #1
Paul Mitch
1965 C-10 Ring and Pinion Gearing Change
I have a 65 C10 that Tacks very high on the freeway. I assume it has 3.73 or higher gears in the rear end. I have a powerglide transmission. I would like to go to a 3.08 set up.
Is this a straight forward swap. What do I need to look out for when buying a ring and pinion gear and bearing kit?
Is setting up the gears difficult?
Thanks ,
Paul
Paul Mitch is offline   Reply With Quote
Old 07-22-2015, 01:15 AM   #2
Captainfab
60-66 Nut
Re: 1965 C-10 Ring and Pinion Gearing Change
When changing from 3.73 gears to a higher gear such as 3.08's you will have to change the carrier. Setting up differential gears requires some special tools and a bit of patience as well as being mechanically inclined.
Old 07-22-2015, 11:03 AM   #3
vince1
Changing out your transmission to a 700R4 would be IMO a better option.
vince1 is offline   Reply With Quote
Old 07-22-2015, 11:40 AM   #4
1963c-10
1963c-10's Avatar
Heres the rear diff codes...check the axle tubes for your stamping and it'll tell you what came in it originally
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-22-2015, 09:37 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Professional rebuild with parts will run around $1500.
A 7004r installed in your driveway would be about half and would give tons more enjoyment
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-23-2015, 02:14 AM   #6
64chevtruck
Howdy, I had 3.73 gears in my 70 GMC with a 3 on the tree, I bought some 308 rear ends out of 80s suburbans that were 5 lug for 50 apiece, I liked my rims so I just switched the axles out, was a fast easy switch. Now I got 308s and 6 lugs, no problem. Pics and more info in my build thread.
Hard to argue with a 700R4 though....
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
