09-07-2003, 03:36 PM | #1 |
Turn signal help
I click the right one works perfect, Click the left one it blinks BUT the right one blinks too not as bright though ? Where are the wires i should check? Pics would help of what i should check. Thanks
Soon to have 68 SWB 350 with Turbo350 |
09-07-2003, 04:04 PM | #2 |
I need a brake!
I had the same problem simply changing out both blinker and hazzard flashers solved it.
JP MEMBER OF THE DISCS UP FRONT CLUB 1971 Chevy C10 |
09-07-2003, 04:27 PM | #3 |
I just put two new ones in still doin it. Any other ideas ?
09-07-2003, 05:01 PM | #4 |
I am a Referee of life.
Check to be sure you have good grounds at both sockets.The # of electrical ???s on this board that have been solved by tracing out a bad ground are almost as numerous as electrical problems period.It seems that over the years many of the ground wires on these trucks get loose or deleted and cause all types of electrical gremlins.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-07-2003, 05:02 PM | #5 |
Where are the sockets your talking about ?
09-07-2003, 07:47 PM | #6 |
ttt
09-07-2003, 09:07 PM | #7 |
ttt
09-07-2003, 11:30 PM | #8 |
Does it blink in the front and rear, or just one?
U.S.A.F. 68' C-10 Stepside 305 w/ 4 speed |
09-07-2003, 11:43 PM | #9 |
its all about the +6 inches
Have you tried swapping bulbs yet?
09-08-2003, 08:21 AM | #10 |
Yes I put new bulbs in
09-08-2003, 08:25 AM | #11 |
It blinks in front and rear
09-08-2003, 08:53 AM | #12 |
Mine does the same thing only either way you turn it it lights boths sides front and back... Very annoying I'm getting tired of using hand signals. Plus, I don't think many people know what the hell I'm doing when I put my arm out the window.
Jon 1968 C10 Custom |
09-08-2003, 09:01 AM | #13 |
I would suggest working on the light that is dim. It almost has to be a ground. The sockets lose ground between the socket and housing where they are swedged in . With the blinker on and the lens off, use a well grounded wire and touch the socket/bulb to see if it will brighten up.
Is the dim one in front or rear? Jim |
09-08-2003, 10:16 AM | #14 |
rear
09-08-2003, 12:59 PM | #15 |
Weapons Of Construction
Did you put the bulb in backwards? It's hard to do, but apparently (judging from other cars driving around at night) it can be done.
Turn on your park lights. If the one that was dim when the T/S was on is now brighter than the other side, you've put the bulb in backwards.
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
09-08-2003, 05:46 PM | #16 |
still doing it
09-09-2003, 12:38 PM | #17 |
Look at the filaments when the turn signal is on. The fatter one should be lighting up, I think. If in doubt, look at the other side and verify that the same filaments are lighting.
You may have a weak wire (gone resistive) or contact. It might also help to clean the part of the socket that contacts the base of the lamp. Sometimes you can bend the sides in a little to get it to work better. Keep us posted! And good luck finding it!!
09-09-2003, 01:03 PM | #18 |
ty
