Old 07-22-2015, 03:17 AM   #1
Caleb
Caleb's Avatar
5.3 swap wont run correctly
my 5.3 out of an 02' 1500 will start and idle around 400 RPM for about 30 seconds before it dies. i have no clue what is wrong. took it to 2 shops both dont know whats wrong and they refused to work on it said it wasnt worth their time. so instead of wasting time with other people im gonna finish this thing myslef. i have 51PSI fuel pressure. got new intake gasket because it failed my smoke test. i thought it may be a bad MAF sensor. it backfires through intake a little and the plugs look fouled. got new ones and when i get it back im gonna swap it out. it has a p0030 trouble code. also according to the shops the STFT and the LTFT dont log at all they stay 0%. builder said he gonna reflash a new PCM and send it to me to rule that out. i could use some serious help. thank you.
1986 K1500 Pro-Street 4x4
Caleb is offline   Reply With Quote
Old 07-24-2015, 06:44 AM   #2
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Re: 5.3 swap wont run correctly
One possibility is that the oxygen sensor wires may be connected to the wrong side of the engine. The longer it runs the worse it gets--
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 07-31-2015, 02:35 PM   #3
White knuckle Garage
White knuckle Garage's Avatar
Potential causes of a P0030 trouble code may include:
•Failed or damaged heater circuit element inside the HO2S
•Open on the O2 sensor heater's ground circuit
•Open or short on O2 sensor heater's B+ battery feed (on some vehicles this may be the control circuit)
•Possible ECM failure (less likely)
Possible Solutions
Many times a HO2 sensors heater element may go bad due to age or impact. Keep this in mind when making your inspection. Make a visual inspection of the Bank 1,1 O2 sensor. Repair any damaged wiring from contact with exhaust.
If HO2 Sensor itself appears to have been damaged, replace it. If a visual inspection reveals no obvious problems, viewing the faulty heater circuit on a scan tool may reveal if the fault is currently occurring. If the scan tool datastream shows that the Bank 1,1 heater element is pulling 0 amps then suspect an open in the circuit. Check for blown fuses and then disconnect the O2 sensor connector.
With key on engine off use a voltmeter to check for 12 volts fused battery feed to the heater element. If there is no voltage present, repair open or short in the B+ feed circuit remembering to replace any fuse blown from the short. If the B+ battery feed is intact, remove the ground (control) circuit from the ECM wiring connector and check for resistance on the circuit. If there is infinite resistance, repair open in the circuit. If the control circuit checks out, suspect a bad O2 sensor. Replace and re-check.
White knuckle Garage is offline   Reply With Quote
