![]() Join Date: Jun 2015
Dash pad removal?
Any secret words of wisdom on how to remove the dash pad?
I think mine is rusted to the dash. Secret fasteners?
68 C10 SSB 383 12 Charger 6.4L 12 Accord 3.5L (Wife's ride) 05 Ram 1500 5.7L My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545 |
Re: Dash pad removal?
subscribed
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
![]() Join Date: Jul 2001
On the back side of the dash pad, the forward leading curved edge. Several studs with nuts holding the pad in place. Don't recall exact nut size, believe it is maybe 3/8", not sure. Been several years since I replaced mine, if I recall "think" it is a total of 6 or 7 fasteners. A case of needing to stand on your head with a flashlight and look up under the dash to see where they are. MUCH easier to remove if the glove box cardboard is out of the way and also the radio if you have to remove it for any reason. If those items are still in place, becomes a real pain in the **s job,
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
What he said. I believe there should be 10 studs. I think
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
![]() Join Date: Feb 2004
Just did mine. It was easier since the glove box, heater controls and box were out. I also backed the instrument cluster off to get to the studs on the drivers side. Remember there are also 4-5 black screws on the front side.
![]() Join Date: Sep 2007
you will best of removing the cluster, radio and glovebox cardboard for easiest access to the nuts
1967custom |
72 GMC
. . . and centr dash a/c vent if you have one.
KEL Members I have met : 2014.02.01: bruceman1968, Mr Handy, colgad, RenoKeene, CaptRMW |
I have found it is easier to remove if you have 1/4" drive ratchet and for the delux way if you have a palm ratchet you can breexe right thru if with a minimum of lost blood
...and possibly the speaker if it's still there. Best to get everything out of your way.
You should be able to slide your hand up behind the dash and feel for the 6 or 7 studs. If I recall correctly, you'll need a 3/8" deep well socket for the nuts. Not a lot of room, so flex shafts, universal joints, and/or palm ratchet will help in tight quarters. If you're putting in a replacement dash pad, don't over-tighten the nuts. The first pad I ever did I cranked down the nuts and it may have led to some minor warping. |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
+1 on the over tightening! Snug is plenty tight and as mentioned, there are screws in front as well as the nuts inside the dash. The dash pad could very well be THE number one most difficult R&R component on these trucks! Good Luck!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
use a torch followed by a hammer and chisel. just kidding. what the above guys say
sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. ![]() |
#13 |
I just removed mine, did not remove cluster or radio but did destroy the glove box liner trying to remove it ? The nuts are 3/8. You can access most thru the rectangle shaped cut outs in face of dash with a small open end wrench. The one at drivers side end is able to be reached with a long skinny arm, like mine ! Also you can gain access by removing defroster vents to get at a couple in the center portion. Good luck and be patient, it's worth it. While at it repainted top of dash with flatt non glare paint.......
71 C-20 07 Magnum RT AWD |
#14 |
Got it off. Had 8 nuts, I've heard these things are called cymbal nuts. Very thin. Took a 1/2 inch socket. Maybe not factory, but that's how it was.
