07-23-2015, 09:10 PM | #1 |
PITbut
Booster and master cylinder options?
There any other options then the ugly big ole booster and master cylinder on 70 blazer 4wd??
I'm shaving the passenger side and looking at options for the drivers side.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
07-23-2015, 10:05 PM | #2 |
Re: Booster and master cylinder options?
I just picked up a dual 9 inch booster with a Corvette style master and proportioning valve from Tuff Stuff. I was concerned with fitment issues with the 5.3 I will be installing. I will be ditching the front drums and fabbing my own front disc conversion using 03 style dual piston calipers and 11.5 diameter rotors. If my calculations are correct, it should just clear a stock 15" rim.
If you plan on keeping the drums, then a proper master is also available. |
07-24-2015, 12:51 PM | #3 | |
PITbut
07-24-2015, 04:27 PM | #4 |
Hydra boost ??
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
07-24-2015, 05:03 PM | #5 |
PITbut
Thats definetly better. I will search on that.
Dont they have a setup that goes under the dash?
07-25-2015, 04:37 AM | #6 |
Collector of Projects
I used a a forum members (CaptainFab) bracket for my hydraboost swap. It can also be used for a smaller booster and it pulls the whole assembly tighter to the firewall.
http://www.67-72chevytrucks.com/vboa...d.php?t=347484 |
