Old 07-24-2015, 05:27 AM   #1
Metaldoc
Metaldoc's Avatar
rear outer wheel well question
any ideas to fill in the outer wheel well after I've raised the bed 2". This piece was swiss cheese so new ones have to be made.
Metaldoc is offline   Reply With Quote
Old 07-24-2015, 09:53 PM   #2
Metaldoc
Metaldoc's Avatar
Re: rear outer wheel well question
this is what it is now
Old 07-25-2015, 09:48 AM   #3
65standard
65standard's Avatar
Don't understand the question. Raise the bed 2"??? Why??? Fill the wheel openings on the bed sides???
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 07-25-2015, 10:19 AM   #4
jakewalter
jakewalter's Avatar
It looks like an excellent repair on the outer fender.
What is your next challenge?
You might want to move this to your build thread.
Jake
1967 Chevy SBSS Bone stock
1974 Chevy Cheyenne 4wd long bed
1985 Chevy Scottsdale 4wd long bed
2000 Chevy 1 ton 4wd dually quad cab
2004 GMC Sierra 4wd Super cab long bed
jakewalter is offline   Reply With Quote
Old 07-25-2015, 10:37 AM   #5
jakewalter
jakewalter's Avatar
Check out some of 67cheby builds.
The threads are long but full of great ideas.
Jake
Old 07-25-2015, 12:01 PM   #6
Metaldoc
Metaldoc's Avatar
I raised all the bolt holes and cut out the lower inner well. My question is any ideas on filling in this area for more tire clearance
Old 08-14-2015, 06:55 PM   #7
Metaldoc
Metaldoc's Avatar
this was the fix
Old 08-14-2015, 08:45 PM   #8
vidman
vidman's Avatar
This is what i did to my bedsides
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 08-14-2015, 09:25 PM   #9
Metaldoc
Metaldoc's Avatar
almost the same, nice work. I also raised the bed two inches and widened the inner fender two inches
Old 02-28-2016, 10:56 PM   #10
dec010974
dec010974's Avatar
Hello to all. I'm trying to bring back the dead. What was used to fill in the gaps vidman or metal doc? Was it able to be purchased?
dec010974 is offline   Reply With Quote
Old 02-28-2016, 11:23 PM   #11
dec010974
dec010974's Avatar
This is what I have so far.
Old 02-28-2016, 11:28 PM   #12
dec010974
dec010974's Avatar
I needed to cut the rear, inner wheel well for Clearence. it interfered. I have a bagged c10.
Old 02-29-2016, 12:11 AM   #13
Metaldoc
Metaldoc's Avatar
Hand fabbed inners and raised holes 2 inches. folded the edge and spot weld the inner fender to it. There are no store replacements for this. I have more pics on my process.
Old 03-01-2016, 09:08 AM   #14
dec010974
dec010974's Avatar
Thanks metaldoc. What guage metal did you use for this wheel well mod? It seems pretty this. How did you bend the edge on the bed side inner wheel well? Also, if you don't mind, can you post more pics. Thanks, Clark.
Old 03-01-2016, 12:42 PM   #15
Metaldoc
Metaldoc's Avatar
I use 19 ga steel and bend it on my table edge. 1 inch thick solid steel 22"x33" table top. The edge of the wheel well I bent with a bar, 1/2 " deep cut as shown in pic. I cut the old well out and used it as the template. I drilled holes to spot weld the upper edge, fit it under the bottom on the well and tacked that edge together.
Old 03-01-2016, 08:48 PM   #16
vidman
vidman's Avatar
I think i used 18 gauge on mine. been 2 years now, and used 2 pieces on each side and welded them together..My buddy runs a hot rod shop, so he has all kinds of good stuff laying around.....
