07-24-2015, 05:50 PM | #1 |
Tail Light Picture Request
I determined that I needed to replace the crappy tail lights and bought all new LED in some nice chrome housing. Here is the issue. The existing lights bolt through the side of the stake pocket. The new ones mount to a plate that extends from the back of the stake pocket.
What I need is a photo of how they mount correctly and where the wires pass back through the stake pocket. Please and thanks. The picture is what I will be installing.
Tire Guy ---------------------------- Yep I'm a Corvette Guy... 2014 Corvette Stingray 1957 Chevy 3100 |
07-24-2015, 06:36 PM | #2 |
Re: Tail Light Picture Request
Tire Guy, this is gonna be a nice reliable truck with the way you're working on it, good job.
I have no picture of which you are asking, but, I may save you time if you are not familiar with the extremely low amperage needed to light those lights. I also used LED lights, the current draw is so low that a regular flasher will not flash. You might need a special flasher that has it's own ground and is made for LED light usage. The new flasher will fit the same as the old flasher, it just has a ground wire you will need to ground. If you already knew this.... perhaps this will useful for someone else, like me when I wired my truck a few months ago. lol
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
07-24-2015, 06:53 PM | #3 | |
07-24-2015, 07:28 PM | #4 |
I believe flasher only gets replaced if front and back are leds. Back only can be fixed by adding a resistor in the wiring so the flasher senses the right resistance. Here is a search, choose your poison...
https://www.google.com/webhp?sourcei...nal%20resistor
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-24-2015, 08:17 PM | #5 | |
07-28-2015, 08:35 AM | #6 |
you can get an electronic flasher at most parts stores for under 10 bucks. much easier than wiring in resistors.
07-28-2015, 11:42 AM | #7 |
Will it work with regular lamps in the circuit (at front) or do all the lamps have to be changed to led's?
07-28-2015, 12:28 PM | #8 |
I put one on my motorcycle when I switched it over to LEDs on the back. It still has a regular turn signal bulbs up front. Just went to Napa and got a standard electronic flasher for a car or truck. From what I can tell, it flashes at the same rate regardless of load unlike the regular mechanical flashers.
07-28-2015, 12:43 PM | #9 |
You thought we forgot about the steering column problem, what did you do ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
07-28-2015, 01:01 PM | #10 |
07-29-2015, 12:16 AM | #11 |
Here ya go. I don't think I needed a special LED flasher and I believe the resistors are already on the LED's. Ran my wiring underneath in stainless conduit.
"Built- not bought" 1958 GMC 150 4x4 in progress 1980 K20- Restored 1985 K3500 Flatbed 58 GMC 4x4 build thread: http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675 |
