Old 09-07-2003, 08:03 PM   #1
hgs_notes
GEARHEAD
hgs_notes's Avatar
Question 71 cig lighter wire ???
The red lead from the fuse panel that goes to the lighter has another red wire that splits a few inches from the panel. Where does the second wire go?
HG
hgs_notes is offline   Reply With Quote
Old 09-07-2003, 08:50 PM   #2
Linus0014
Guest
Posts: n/a
Isn't it a feed for anything else you want to use it for? There should be a plug attached, (Like a male/female).
Old 09-07-2003, 08:54 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
If I remember correctly, the stock radio plugged into that.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-07-2003, 09:23 PM   #4
hgs_notes
GEARHEAD
hgs_notes's Avatar
Thanks alot, I kind of thought it may be a radio feed, but just couldn't remember. Thats the problem with letting a project sit too long.
HG
Old 09-07-2003, 11:56 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Is it a green wire?
My Longhorn has a red and green wire bonded together, the green one is for the light on the lighter, while the red one heats it up.
Old 09-08-2003, 09:25 AM   #6
hgs_notes
GEARHEAD
hgs_notes's Avatar
Your lighter has a light on it? I've never seen that. But no, the wire is red and I have my doubts now about it being for the radio because it's always hot and radio feeds are usually on with the ignition switch.
Old 09-08-2003, 09:35 AM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
There was an lighted cig lighter, I've seen it stock once, but not all that common. The standard lighter has the single red wire as described. I still want to say it's the radio feed but maybe not. Is there a radio spade on the fuse box?
Old 09-08-2003, 10:11 AM   #8
Terry Peerson
Check and see but, I think that is the power to the high-speed of your fan.
Terry Peerson is offline   Reply With Quote
