07-25-2015, 06:34 AM | #1 |
WTB: 307 V8 choke assembly
Got a buddy who has a 69 chevy truck w/ original untouched 307 engine, but missing the little "arm" that connects the choke spring to the 2 bbl carb, and missing the choke spring and metal housing too....anyone got all three pieces to sell? PM please as I do not get automatic notifications....thanks! Steve
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
07-25-2015, 08:34 AM | #2 |
Re: WTB: 307 V8 choke assembly
I may have 1 let me look
07-26-2015, 12:51 PM | #3 |
09-12-2015, 11:59 AM | #4 |
Back to the top - my buddy needs this 307 Choke stuff pretty bad if anyone has them...
09-12-2015, 04:52 PM | #5 |
Not sure if this is from a 307 but it is from a 2BBL Rochester carb/intake combo. Not sure of the intake mfg. date, did not take time to run the numbers. Let me know if this is what you are looking for. Mount screw is RUSTED tight, will have to grind it off. PM sent for notification.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
09-13-2015, 09:56 AM | #6 |
Also there is 2 differant styles of choke housings the dished or the flat style if you have a picture of your intake where the choke goes it will tell me what one you need
09-13-2015, 01:29 PM | #7 |
Thank you Ironhorse and WETOWM - let me go snap a shot of the choke boss on the intake in question and we can see which one I need first....will post to this thread
09-21-2015, 12:19 PM | #8 |
Did you find out which choke style you need? Have not drilled/ground off the screw head yet, checking if still interested?
09-21-2015, 02:35 PM | #9 |
I meant to get by the mechanic shop Friday and didn't so trying again shortly....will take a pic of the choke boss on the intake and post it so we can make sure we get the right one....thanks! Steve
10-04-2015, 06:36 PM | #10 |
Ironhorse / WETOWM - I finally got off my butt and got you some pictures. Looks like the 307 choke boss on the intake is pretty much identical to what I see in Ironhorses pictures above - so it looks like this is exactly what we need to fix this truck with. Need the arm, cover, spring etc. See what you think
10-04-2015, 06:38 PM | #11 |
here's the pics
10-04-2015, 07:17 PM | #12 |
Steve, looks to be very similar to the choke assembly in my pic other than the housing on mine is more square where your housing pictured seems more rounded. Not sure if that would be an issue or not, don't think it would but ??
If you think it will work I will drill or chisel the screw out tomorrow since it is rusted tight and post more pics of it removed it wanted. Let me know,
10-04-2015, 07:39 PM | #13 |
Iron, I am going to take the risk either way - please PM payment info and I'll get you squared up - I do paypal too if that is simpler
10-04-2015, 08:38 PM | #14 |
Will remove the choke assembly tomorrow, Steve. PM sent
