Old 07-25-2015, 11:48 AM   #1
72 K20
72 K20's Avatar
speed warning speedometer parts
Hi ! I have a speed warning speedo in a cluster that came in the last 72 that I bought. The speedo is there with the offset needle and the white needle. But that's all there is,,, the bezel has the hole where I assume there was a knob or dial to set the warning needle . From what I have read there should be a buzzer or something on the back side of the bezel.
Is there anywhere to get these parts ? Wasn't the speed warning a 69 year only option ? I don't know a lot about these ,, and don't really have any plans on restoring it unless the parts to complete it are very affordable .
Thank you in advance for any and all input ! Have a great day !!!
Tom
72 K20 is offline   Reply With Quote
Old 07-25-2015, 11:57 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: speed warning speedometer parts
You are missing the adjustment cable. Also need a wiring harness and buzzer. Parts are hard to find. You can become a subscribing member and post a want to buy ad for parts or search for people selling what you need. They were an option from 67-69
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 07-25-2015, 12:01 PM   #3
72 K20
72 K20's Avatar
Could someone post a picture of the back of one of these that is complete ? Then I could get a better idea of what all I would be looking for .
Thank you Leddzepp !! Is the wiring part of the printed circuit or an additional harness ?
Thank You
Tom
Old 07-25-2015, 12:40 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Additional separate harness that runs about $20. Clips onto the brass "lug" or "peg" on the back of the cluster
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 07-25-2015, 12:54 PM   #5
vettedrvr
Tom
Tom:
There are pictures of a complete speed warning speedo. They may not be rare but they are uncommon, expensive when available, and are not reproduced in the aftermarket. Use a little caution, though. When any vendor says, "may need serviced" what he really means is: "I know it doesn't work but I'd be glad to lighten your wallet considerably if you're dumb enough to buy this POS".
Good Luck!
http://www.ebay.com/itm/Original-196...3D131501847944
vettedrvr is offline   Reply With Quote
Old 07-25-2015, 05:44 PM   #6
72 K20
72 K20's Avatar
Wow !!! $295 for just the speedo !
http://www.ebay.com/itm/Original-196...944&rmvSB=true
And like VETTEDRVR said "may need serviced ".
$295 is almost 30% of what I paid for my truck . And I got the whole cluster !!
I think I'll put the one I have in a safe place and add it to my list of assets !!!
I'd be willing to trade this speedo for a fairly solid short box truck !!!!!! LOL !
Old 07-25-2015, 05:51 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Here are couple pics of the front and back of a Speedwarning dash.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-25-2015, 06:05 PM   #8
72 K20
72 K20's Avatar
ALREADY GONE Thank you for the pictures !!
I see the plug-in on the back of the one on ebey,,where does the wiring plug in ?
Also ,, where is the buzzer/alarm located ?
Thank You !! Tom
And by the way ,, that is a very nice looking dash !!!!
Old 07-25-2015, 06:41 PM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: speed warning speedometer parts
I sold this a couple of years ago. It had the speed warning, tach and all the gauges with a clock I added.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-25-2015, 06:46 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Here is a factory correct buzzer with harness. The white wire clips to the brass lug on the back, the orange wire goes to a keyed power source. The buzzer mounts behind the dash.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 07-25-2015, 06:54 PM   #11
leddzepp
Moderator
leddzepp's Avatar
I've seen the cable mounted in various spots on the bezel. Here is the one in my truck, I copied the location from the original bezel I had.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 07-26-2015, 12:43 AM   #12
Already Gone
I have some pics of the relay in its original
Location in a truck. I have to find them
On my computer and will do when I get some time in the next day or two.
