07-25-2015, 01:06 PM | #1 |
Anyone use Caswell "cold" black oxide kit? Results?
Considering this for refinishing bolts and other small items. Have you used this and were the results good?
http://www.caswellplating.com/metal-...xide-kits.html
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-25-2015, 01:13 PM | #2 | |
Re: Anyone use Caswell "cold" black oxide kit? Results?
07-25-2015, 01:19 PM | #3 |
I'm also considering one of these: http://www.stainlesssteelcreations.net/
And also considering this. I believe this is a new product. A bit on the expensive side: http://www.cjponyparts.com/eastwood-...1vYaAtMN8P8HAQ
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-25-2015 at 01:30 PM. |
07-25-2015, 01:36 PM | #4 | |
07-25-2015, 01:51 PM | #5 |
Thanks. I read where parkerizing bolts is a bad idea. That said, the guy blew it all the way around and may have been misinformed.
07-25-2015, 03:28 PM | #6 |
Carpe manana
Ive had several parts reparkerized and the cost has been reasonable and with excellent results. If you have a local plating shop it might be worth inquiring as to their minimum batch cost, which should do a fair amount of parts.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
07-25-2015, 05:22 PM | #7 | |
Edit: Ha, there's a place a mile from me. They do exactly that.
07-26-2015, 08:31 AM | #8 |
I have used 2 eastwood kits it worked well for some small clips,nuts and bolts but anything bigger than that i didnt have good luck with it.
what they sell you as the "kit" is pretty much a joke. just buy the "solution" and not the kit. and if you have anything bigger than nuts an bolts better get 2-3 of the bottles. when i'm ready i'm gonna try caswells product this time they have better reviews.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
07-26-2015, 10:43 AM | #9 |
The Older Generation
The thing I found with the Caswell product is that the parts have to be absolutely clean. If there is any rust on them at all it won't work.... LockDoc
07-26-2015, 04:48 PM | #10 |
07-27-2015, 11:03 AM | #11 |
X2 on the muratic acid. I buy pool acid from Lowes. It derusts small parts very well. Just be sure to use the solution in a WELL vented area and wear rubber gloves as it can easily burn your skin.
08-07-2015, 12:37 PM | #12 |
A lot of people use it, but muratic acid is not recommended for metal, because it can damage it. I've found white vinegar does a GREAT job of removing rust. You just need to wire brush afterwards.
08-07-2015, 01:25 PM | #13 | |
OBTW, the reactive part of white vinegar is HCL otherwise known as MURIATIC ACID and that, sir, is the same acid that is in your stomach! |
08-07-2015, 04:02 PM | #14 | |
