for those of you who made your own bed wood
So, I made my own bed wood, used some Colorado beetle kill pine. I used all the measurements from GMC Paul and everything fits nicely. I'm at the last stage of drilling the bed bolt mounting holes, and here is where I need to hear what some of you did.
I've been following all of Mar-Ks instructions for drilling the holes and have everything lined up, They say to use 1-9/16 Forstner bit to drill for the offset washers. I cannot find one that size anywhere. I would have to special order it and with shipping would end up being pretty pricey for one bit. The washer is 1-1/2, I imagine the extra 1/16" in the hole is for the wood to expand and contract. What did you do? just use a 1.5" Forstner and call it good? or I thought of using the 1.2" bit and then widening the hole a bit with a dremel. Any insight from experiences is appreciated before I drill my boards. |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: for those of you who made your own bed wood
Hole saw for the perimeter the router to depth the rest. Key here is what you got or can borrow.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Do you have a dremel? Use the 1.5" and take a dremel with a sanding wheel to take just a little extra off the edge. You can drop the washers in the indentation and enlarge the hole until you are happy with it.
Keep in mind most people put finish on the wood after they drill it, and that's likely the reason for most of that extra 1/16". When you put finish on the wood it will fill that 1.5" hole in a little.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#5 | |
ron |
#7 | |
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
Moderator
![]() Join Date: Dec 2012
I took one of the washers to the store and bought the drill bit that was one size bigger.
Posted via Mobile Device |
I think I'm just going to do the dremel shave. The next size bigger bit is 1-5/8" and I don't want that big of a hole if I can avoid it,
Yes, ordering one online is easy, I'm just sick of ordering every last little thing I need and having to wait and pay double what it costs to ship it. Thanks for the input, I figured it was an easy solution, I just wanted to make sure there wasn't something I was missing, or not thinking about. |
