Old 07-26-2015, 04:09 PM   #1
Dburger
Dburger's Avatar
1953 Suburban with Buick V6 Power
I got this truck for free almost 2 years ago. It had no engine or transmission, but previously was V8 powered as evidenced by some pretty bad mounts that were in it and some other relocated items. There is a good amount of rust, but it's savable. I decided to let my spare GM V8's sit a while longer and drop a 231 V6/THM200 out of our old 1978 Buick Skylark in.
This truck was the honorary guinea pig for testing bucket seats
With the front bumper and apron on
Terrible mounts:
Front clip removal for drivetrain installation:
Drivetrain dropped in, nothing hooked up:
Next step is to take the engine and transmission back out to make a few cuts, then put it back in with the intent to actually start. Also open to adding a turbo, but that's a long way away. Got to patch the floor and rust below the rear doors.
1953 Suburban Carryall 3106, 1993 S10 4x4 ext cab
1958 Suburban Carryall 3116 ex school bus
1959 Apache 36, 1984 C30 3+3 DRW 6.2 4MT
1967 C10 fleetside LWB, 1969 Chevy Suburban C10
1972 GMC Suburban C10
1972 Chevy Suburban C10 clam shell/tailgate
Dburger is offline   Reply With Quote
Old 07-27-2015, 03:09 PM   #2
Iceburgh
Iceburgh's Avatar
Re: 1953 Suburban with Buick V6 Power
Good on you for doing something different.
Not sure what kind of HP that motor makes, and these things are not light.
Safe to say that you wont be going to the 1320 anytime soon.
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 07-27-2015, 03:37 PM   #3
Advanced Design
Advanced Design's Avatar
It is good to see another Burb going together.
Advanced Design is offline   Reply With Quote
Old 07-27-2015, 10:49 PM   #4
Dburger
Dburger's Avatar
Thanks! These engines make about 125 horsepower or so, but I think I can manage until I add boost. I've got a mild 350 in my '72 Chevy a 383 stroker engine I could use in another vehicle if I wanted to go drag racing. Might put my long unused 200-4R overdrive trans with this V6.
Thank you. I'll have to make some threads for my '58 Suburban and '59 truck.
Old 08-01-2016, 03:46 PM   #5
Dburger
Dburger's Avatar
Almost a year later I have the Buick engine almost ready to start. It has a radiator from a 1948 Plymouth Special Deluxe like mine, and I have a Jeep transmission cooler that I'll be hooking up and then we should be good to go.
However, the previous owner of this truck really did some crazy stuff to it. The rear end isn't quite square and the u bolts are too short. Chevy 12 bolt rear end with a half Pontiac, half Chevy driveshaft that I made.
dslr51 026 by FordTorino73, on Flickr
dslr51 029 by FordTorino73, on Flickr
dslr51 032 by FordTorino73, on Flickr
Put in some brake lines and now it stops:
dslr58 002 by FordTorino73, on Flickr
dslr58 006 by FordTorino73, on Flickr
Also put in the rather sketchy master cylinder that the previous owner had in it just for yard driving purposes:
dslr57 063 by FordTorino73, on Flickr
Untitled by FordTorino73, on Flickr
dslr61 274 by FordTorino73, on Flickr
1978 Buick 3.8 V6 and 1948 Plymouth radiator:
DSC_0006 by FordTorino73, on Flickr
DSC_0009 by FordTorino73, on Flickr
DSC_0011 by FordTorino73, on Flickr
Also started shooting some clear onto the "patina"
DSC_0029 by FordTorino73, on Flickr
DSC_0032 by FordTorino73, on Flickr
Cranked when I touched a wire to the positive terminal, but I still need to hook up that trans cooler and actually put an ignition switch in.
Because Roadkill
Old 08-01-2016, 04:08 PM   #6
RockinKees
RockinKees's Avatar
Nice project!
A bit of an unusual engine choice but it fits nice in there
What are your further plans with it?
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 08-02-2016, 01:47 AM   #7
iowaboynca
iowaboynca's Avatar
Maybe find the supercharger that GM was throwing on 3.8s in the mid 90s...
not sure if intake is the same, but heaven forbid if GM ever changed anything that worked...that would make a nice little sleeper with a little work.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 08-02-2016, 08:58 PM   #8
youngrodder
youngrodder's Avatar
Pretty cool project...
I might be partial.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
