Aftermarket door hinges
Does anyone make a quality, good-fitting door hinge for these trucks? I'm in the process of trying to repair the LH hinges on my '66 and have partially collapsed the opening on the lower hinge. I don't really see any way of undoing what I did with the press and am looking into replacing it instead. I'm hearing stories of the aftermarket hinges not fitting well, though. Does anyone have any experience with aftermarket hinges?
Posted via Mobile Device |
Re: Aftermarket door hinges
Hey Chris. U need the driver side? Pm me your address and I will send u a set. U will have to put new pins and bushings but they are yours if u want them.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
PM sent, Jay. Thank you, sir, for the kind offer!!
Can anyone shed any light on the best method for removing the old pins without destroying the hinges? I ain't had much luck so far with mine.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
