Old 07-26-2015, 05:14 PM   #1
mikagraham
84 chevy c10 305 vacuum help
I have read other msgs on here and try to view the photos but it isnt working. I have 84 chevy c10 305 with Rochester quad carb. There r 2 vacuum lines coming off the back i cant figure out. Can anyone help? Can someone add photos of thier truck and vacuum lines. Thanks.
mikagraham is offline   Reply With Quote
Old 07-27-2015, 11:25 PM   #2
mikagraham
Anyone?
Old 07-28-2015, 06:23 PM   #3
beamn7
Re: 84 chevy c10 305 vacuum help
Federal emissions or CA emissions?
beamn7 is offline   Reply With Quote
Old 07-28-2015, 06:30 PM   #4
mikagraham
How do i know?
Old 07-29-2015, 11:50 PM   #5
PAWS 72
PAWS 72's Avatar
Probably Federal. Not Cali. Seeing he's is Missouri
PAWS 72 is offline   Reply With Quote
Old 07-31-2015, 09:46 AM   #6
mikagraham
Thats wat i was thinking. Still need sum help. Thanks
Old 07-31-2015, 12:06 PM   #7
geezer#99
geezer#99's Avatar
Post a pic of what you got!
Easier for us to help fix your problem if we can see it!
Old 08-01-2015, 06:10 AM   #8
chengny
chengny's Avatar
Below is the vacuum diagram for a truck with an XSS EPA code. I knew the engine size and year, but without any more info I had to guess on some stuff. In addition to 305/1984, I used automatic transmission, federal & low altitude. "Federal low altitude" just means not California and not high altitude (essentially the standard emissions package). But it really doesn't matter as far as this particular issue is concerned - the vacuum diagram for every 1984 with a 305 and AT had only one hose connected to the back of the carburetor. And in every case that hose went to the EGR bleed solenoid. The other hose is probably the vacuum supply to the power brake booster.
chengny is offline   Reply With Quote
