Old 07-26-2015, 06:30 PM   #1
pamoffa
fuel filler neck
I would like to change my rotted fuel filler neck and noticed the ones you can buy seem different, I dont see a hose clamp on the new ones and the rubber hose is already attached to the new one my concern is with the new one I will need to go through the trouble of replacing the hose also. has anyone installed one of these and had to use the new rubber hose. this is what it looks like hope the link works. http://www.autopartswarehouse.com/sk.../RB577095.html
pamoffa is offline   Reply With Quote
Old 07-26-2015, 06:41 PM   #2
pamoffa
Re: fuel filler neck
Does the new smaller hose slide easily through the old large hose
Old 07-27-2015, 08:46 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
That hose is actually the vent hose. It lets air escape when you fill the tank. It's designed just like the original one. My only concern is dorman is fine as long as it isn't made from metal, rubber, or plastic
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 07-28-2015, 07:08 PM   #4
pamoffa
I bought the dorman filler neck and installed it today, I didn't remove the old big hose The dorman slid right in the big hose with no problem. The old filler was so bad hopefully it cures my po442 the hard part was getting the broken part of the old filler out of the end of the big hose.
